RAMSOMAIR
FACT
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
Did this today. I can't imagine trying to do it without taking off the throttle body. Not a horrible job, but time consuming. Thanks to everyone on this thread as the feedback helped.
Turbomax
- Oct 31, 2021
- Ottawa
- 2018 Yamaha Sidewinder
2014 Yamaha Viper
1983 Yamaha SRV 540
Old sleds:
1999 SRX 700
2003 Yamaha Viper SX 700
2008 Yamaha Phazer
I finished this today and also agree with snowdust. I tried without removing the throttle body but was getting too frustrated. I didn’t remove the throttle bodies fully from the sled, but by removing all the connections to it and removing the top steering post mount I was able to pull on the throttle bodies and remove each intake flange to do the work on the hose clamps. You can then re-install the flange with the hose clamps already re-worked without risking losing pieces. Something that really helps is long hex bit sockets (ball ended ideally).
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
So, if I read things correctly. Stock winders do not need to make this adjustment to clamp spacers?
Turboflash
- Mar 18, 2019
- Southern MN
Well, maybe not but IMO it's a situation of either you presently have boost leaks (even if minor) or you're going to have boost leaks. So pretty much you're gonna need to do it sometime.
ViperSbite
- Aug 23, 2005
- 2025 Sidewinder LTX-LE
2023 Sidewinder SRX
2004 Viper S
- Northern Illinois
Hope everyone had a nice Christmas!!
I had a question on this for the guys that removed the throttle body assembly. I removed the connector to the fuel rail, assume I have to remove the pressure regulator as well if I want to keep things intact and avoid removing injectors, etc.?
Appreciate any input!! Thx!!
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
You don't have to unhook any of the lines. Just pull the throttle bodies out and pull far enough out to remove the rubber boots and clamps from in between. There is just enough room to do it without unhooking any lines. Just do one boot at a time on the bench and re-install, the three boots are different and you don't want to mix them up.
ViperSbite
- Aug 23, 2005
2023 Sidewinder SRX
2004 Viper S
- Northern Illinois
Ok, that makes sense, thank you. I'll give that a go, one at a time, this afternoon!!
Thx again.
Thx again.
Kuzzy
- Dec 6, 2020
- saskatchewan
- 2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
This is on my list of things to do... I've completely gutted the chain case pulled the track, F'd around with my suspension and wiring but somehow messing with these intake boots and anything to do with clutching makes me Very nervous. However once I overcome those 2 challenges, nothing much is going to be in the way of me mastering these sidewinders in my sleep.
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
- Yamaha nypex mcx 400
Why not use normal hoose clamps istead of the yamaha stock clamps on the rubber boots? I dont see any problem with that if you cut away the rubber guide for the stock clamp? I pull 30 psi on my sled on stock tension so maybe I should fix that...
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
The clamps and boots have notches in them so the clamps won't rotate.
Here is a photo from the bottom of the throttle body.
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
Yes, but if you cut away the notches? Cant see any problem then too use a normal hoose clamp?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
The inside is also notched so the boots don't rotate. May require some grinding of metal.
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
Yea, but if I use the stock rubber boots, and just cut away the outside notch. Then a normal hoose clamp can be used and you can have all tighten from under the TB. Will try tomorrow but cant see why that should be a problem
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I dont remember if their is anti rotation tabs inside.
Your best bet is just to remove the throttle bodies and find out.
Why not put silicone hoses in place then with real clamps instead of hose clamps that will tear up your hose.
