DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Way easier! IMOMost guys find it easiest just to pull the tb off and remove clamp
Firedawg1998
- Oct 17, 2018
- Sudbury, Ontario
- 2019 srx
Hurricane PM bundle
2012 apex xtx
2012 vector gt
Great.... something else I'll have to do this week while the lakes continue to strengthen. I really want to go out and give her a go.... but I also dont enjoy swimming without taking a hot sauna first this time of year.....
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Got my TBs off and found this small rubber gasket laying in my left throttle body.Way easier! IMO
I looks like a match for the injector but none have it.
This rail has been changed out by dealer years ago, but does it look familiar to any of you who have tackled this job?
Turboflash
- Mar 18, 2019
- Southern MN
Hard to see in pic but maybe one of those insulating washers for the bolts that hold fuel rail on?Got my TBs off and found this small rubber gasket laying in my left throttle body.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I did take pics first so I shall look, but if those bolts you mention are supposed to have those insulated washer, it only had one! Much better then belonging on the injectors!Hard to see in pic but maybe one of those insulating washers for the bolts that hold fuel rail on?
Thanks.
Turboflash
- Mar 18, 2019
- Southern MN
Both should have insulated washers under screw head on top of injector rail.I did take pics first so I shall look, but if those bolts you mention are supposed to have those insulated washer, it only had one! Much better then belonging on the injectors!
Thanks.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
That is very nice to hear!Both should have insulated washers under screw head on top of injector rail.
I shall get another and add them to the bolt heads!
Thank again Turboflash! Much appreciated for sure!!!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Here’s a pic prior to taking the rail off!That is very nice to hear!
The left may have one on it but the right does not! Just hard to see as the pic gets blurry once zoomed in!
SPM
- Nov 18, 2018
- so. mn
- 2018 Sidewinder L-TX LE
Can anyone tell me what the ID. and OD. of the factory clamp spacer is? I would like to make some new ones up before I start to change them out. From what I've seen on here, .125 to .170 is the desired length. Thanks
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Did not measure the I.D. Or O.D. Of those .250” spacers during the process of minimizing their length to .170”, but I did see where a vendor on TY sells the .170” version ready for you to install! If I were to do that again, that’s what I would try!Can anyone tell me what the ID. and OD. of the factory clamp spacer is? I would like to make some new ones up before I start to change them out. From what I've seen on here, .125 to .170 is the desired length. Thanks
SPM
- Nov 18, 2018
- so. mn
I will check into that. These would be easy for me to make at work on a lathe if I had the specs.Did not measure the I.D. Or O.D. Of those .250” spacers during the process of minimizing their length to .170”, but I did see where a vendor on TY sells the .170” version ready for you to install! If I were to do that again, that’s what I would try!
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Can you say which vendor?Did not measure the I.D. Or O.D. Of those .250” spacers during the process of minimizing their length to .170”, but I did see where a vendor on TY sells the .170” version ready for you to install! If I were to do that again, that’s what I would try!
Kuzzy
- Dec 6, 2020
- saskatchewan
- 2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
I remember seeing some on Hurricane's website a while backCan you say which vendor?
Fords4life
- Dec 7, 2021
- South Dakota
I uesed .25" brake line cut to .150" long. Was guick and easy, tubing cutter leaves clean straight cuts with little inside clean up.
Fords4life
- Dec 7, 2021
- South Dakota
- 7K
- 24K
- 9K
