stingray719
Ride report:
The heavier spring (145#) definitely helped. I think I need to go more pre-load though. I set it at 1/4" pre-load or 1.750" from the bottom. I'm going to turn it up another 1/4" for a total of 2" from the bottom. That will still leave another 7/8" of thread left for additional tuning.
Just a heads up, my spring is 1/4" longer than the stock spring, so my #'s my not directly cross over to stock!
Happy to see good results from this mod from somebody that tried it. Thanks!
turbo800
- Jul 24, 2014
- UT
- '15 Viper MTX 162 LE w/ MPI 180 turbo
Talking to Nate from Zbroz when I picked up my spring, it sounds like most their setups run the 140 # spring and some 160's. His personal hillclimb race sled runs the 160.
Its odd to me that YamaCat put such a soft spring in from the factory!
stingray719
Yep seemed odd to me as they put the 135 in the trail sleds. All is well that ends well though now that you have the spring in.
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX (on order)
2018 High Country 9000
2001 SRX 700
Dou You still run the center shock in it's original mounting point? Or in the lower hole?
stingray719
With the new spring nothing else is needed. On our last year Viper I did not change the spring but relocated the lower skid shock mounting hole, short version is do one but not the other. And I recommend changing the spring as it is easier.
stingray719
Or did you mean the skid mounting hole in the chassis? That I would leave as you have it.
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
2001 SRX 700
Yes I mean in the chassis.
TJ-R
- Jan 28, 2013
- 14 Viper XTX
Turbo,
Is that ZBros part #20-0175-300?
turbo800
- Jul 24, 2014
- UT
I have no idea where u got that part #.
TJ-R
- Jan 28, 2013
- 14 Viper XTX
it is a part number from the ZBros website.
Could you please share the part number for the 145lb spring which you purchased from them?
Thank you,
Reaper
- Nov 10, 2005
- Starbuck, Manitoba
- 2014 SR Viper XTX. COTC, Hygear 141 pro link.
Stingray, is that a Yamaha 135lb spring you are using? What hole do you run on the limiter strap with the 135lb spring?
Silvertipgrizz
- Dec 20, 2004
- Interior, Alaska
- 2017 Yamaha Sidewinder BTX SE
Changed the spring out last weekend, huge difference very inexpensive fix. Thanks Stingray
turbo800
- Jul 24, 2014
- UT
TJ-R, I just walked in to their store and bought it in person. It's a $60 spring, but I was able to test this weekend. Bang for the buck is probably the CAT spring.
stingray719
Yes Yamaha (Cat) spring. I run mountains so my limiter is on last hole.
stingray719
Thanks!
