stingray719
Anybody else try it yet? If so please post results.
woodzynh
- Sep 11, 2012
- Nashua, NH
- 2015 Yamaha Viper XTX LE
What does the comparable AC sled have for a spring? I have a XTX LE coming which is like the AC high country, curious the AC comes with a bigger spring? I am 270... Wondering if I should order a spring.
stingray719
My suggestion would be yes, as the 2014 XTX came with 110 pound spring and I would guess 2015 would too? I am 165 pounds and the 110 stock spring was way to weak. The 135 works perfect for me and is about 1/3 of the way up the adjustment. Turbo800 in this thread said he found even stiffer springs that might be what you want (I have not tried those).
BUT, when you seethe sled get the number off the shock and see which spring it came with or post here and I will look it up for you.
Go ride the thing and then decide. There is no sense in adding parts you may or may not need without being able to compare it to the stock handling.What does the comparable AC sled have for a spring? I have a XTX LE coming which is like the AC high country, curious the AC comes with a bigger spring? I am 270... Wondering if I should order a spring.
stingray719
Toooo funny you already changed your shocks and are advising others not too.
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
He's not... I think it would be wise for anyone to ride the sled stock before spending money they might not need to. I rode my sled 700 miles before adding anything to it. Some of the things that I have read about on here I see no need for, some I do. Every rider and riding style is different.
TD Max
I agree. There are some things that are seemingly unanimous like clutching needs work. Some can't hurt.
FWIW Some of the first things that I bought for my Viper will not be used. Hindsight is 20/20
stingray719
I ride mine stock before changes also, my point was on the irony that someone that had changed his advised others not too. Sorry if the intent was not made clear.
stingray719
Yep I have the deflection adjuster I bought that still sits in the package.
TD Max
OK I got this one:
It's called "Do as I say not as I do"
This is most often the best advice that there is.
stingray719
OK I got this one:
You do know your sled already has the 135# spring in it? Its just the XTX and MTX that have the 110# in it.
TD Max
Mine has a multi rate coil not a straight wound like the normal sleds. It also has a very special shock package with reservoirs and clickers in most all positions.
stingray719
Cool, saw you commenting on XTX settings thread and not sure you knew the RTX already has the spring I am suggesting. All good.
TD Max
I'm just waiting for someone to get some REAL seat time in and compare both when using the XTX as a flatlander would. Initial impressions are one thing. Long term is another.
stingray719
I have helped several of you in private messages, please post your results good or bad after testing. Thanks!
