IQS Issues. Code C1526.. Anyone else?
MrSled
Site Admin/CEO
Staff member
Schofield, WI
Website
www.totallyamaha.com
2020 Sidewinder SRX
Anyone have a fix for the Code C1526 left shock? I believe its the main control unit took a dump on the IQS. I flipped shocks from right to left and and the code stayed the same.
Sounds like you have it taken care of—- just an fyi, I had IQS issue where I could not change shock setting at all— bottom line is I had to replace my speedo gage/ dash for the fix—. Tod
These sleds are far from Yamaha quality. Probably best they stopped working with cat and closed the doors.
But what do we go to for power after this?
I might be late to the party but we had one that had a wire pull out of one of the connectors under the hood. Worth a shot.
Not my case. I checked continuity on every wire from to each plug. All good. It’s also never moved when I flip the shock plugs. It still said left shock.
iQS module needs to be replaced , these are sealed modules , I haven't had time to disassemble and diagnose the failed component(s). After the season is over and if I remember ...I will put my electronics surgeon hat on and repair ....I had a few spares but down to one helping out others....keeping it for a just in case part.
it will most likely be a simple component like a cap....
You get this figured out. I’d like to have my old one fixed as a back up.
Plenty of 19's did this, mine included. Module.
Good question. I have 4 winders so we are set for a few years.
I had 3 Tom but I had to sell the 17 LTX LE. My brother wouldn't stop using it so I figured I might as well get a couple bucks for it! lol
