Anyone have a fix for the Code C1526 left shock? I believe its the main control unit took a dump on the IQS. I flipped shocks from right to left and and the code stayed the same.
RAMSOMAIR
Yep, sounds like the control unit. Same happened to my brother's SRX 2 years ago.
New unit and has been good since?Yep, sounds like the control unit. Same happened to my brother's SRX 2 years ago.
RAMSOMAIR
Yes, no issues since we put the new unit in.
Perfect!! Thank you.Yes, no issues since we put the new unit in.
Sounds like you have it taken care of—- just an fyi, I had IQS issue where I could not change shock setting at all— bottom line is I had to replace my speedo gage/ dash for the fix—. Tod
These sleds are far from Yamaha quality. Probably best they stopped working with cat and closed the doors.Sounds like you have it taken care of—- just an fyi, I had IQS issue where I could not change shock setting at all— bottom line is I had to replace my speedo gage/ dash for the fix—. Tod
stgdz
- Mar 27, 2021
- Buffalo MN
But what do we go to for power after this?These sleds are far from Yamaha quality. Probably best they stopped working with cat and closed the doors.
Good question. I have 4 winders so we are set for a few years.But what do we go to for power after this?
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
I might be late to the party but we had one that had a wire pull out of one of the connectors under the hood. Worth a shot.
Not my case. I checked continuity on every wire from to each plug. All good. It’s also never moved when I flip the shock plugs. It still said left shock.I might be late to the party but we had one that had a wire pull out of one of the connectors under the hood. Worth a shot.
no1b4me
- Dec 31, 2016
- 2019 ZR9000 Ltd iACT
iQS module needs to be replaced , these are sealed modules , I haven't had time to disassemble and diagnose the failed component(s). After the season is over and if I remember ...I will put my electronics surgeon hat on and repair ....I had a few spares but down to one helping out others....keeping it for a just in case part.
it will most likely be a simple component like a cap....
You get this figured out. I’d like to have my old one fixed as a back up.iQS module needs to be replaced , these are sealed modules , I haven't had time to disassemble and diagnose the failed component(s). After the season is over and if I remember ...I will put my electronics surgeon hat on and repair ....I had a few spares but down to one helping out others....keeping it for a just in case part.
Plenty of 19's did this, mine included. Module.
I had 3 Tom but I had to sell the 17 LTX LE. My brother wouldn't stop using it so I figured I might as well get a couple bucks for it! lolGood question. I have 4 winders so we are set for a few years.
