My thoughts are a leak or Head gasket... now this is whats strange. No signs of leaking, drives and runs perfect, no overheating, no loss of power, no smell of antifreeze. Fill over flow tank to line. drive 30 to 40 miles. No loss of antifreeze. Keep on driving until about 70 to 80 miles tank empty. Refill it and keep on going , no loss again until we hit about 70 miles. We randomly check out from 0 to 70 miles and it stays at line or above the line when hot.... WTH
Gotta be a leaky line somewhere. I would look at the ones under tunnel. Conditions were right for extreme icing last few weekends. That ice can move things.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Dang, makes me wonder if it's that cracked head syndrome like a few have had where the anti-freeze is getting into oil. ???
Been fighting this on my buds sleds all season.. It has to be a leaky clamp or something.. the damn sled runs perfect.. oil looks perfect, no hard starting.. all the signs of a head gasket are not there.
72Gran
- Jan 25, 2009
- 15 Apex XTX
21 Sidewinder LTX GT
What about a coolant leak at the turbo. The turbo is so hot it just vaporizes the coolant and you don’t see or smell.
We had a leak on that line before, Ill double check that line again..
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Any chance its going out the overflow tube under motor? Any way you could pressure test it?
I am going to pressure test system this week. I thought maybe it was pushing it out but there is no signs of that.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I had a really strange thing happen to mine a couple weeks ago. I had a small spot under my sled one morning and thought I had a leak somewhere.. IT HAD to of come out the overflow tube under motor as I saw a very slight drip coming from the holes under by the access panel. I looked EVERYWHERE after returning home and trying to find it.. Still a mystery to me.. So after this /slight drip I drove it 1300 + miles in 10 days and the anti freeze never moved? So for some reason my sled burped a few ounces out the overflow???
SledFreak
- Feb 7, 2005
- Ontario. Canada
It maybe the one down under the motor to the lower heat exchanger? Its probably a clamp you have not checked yet or cant see?
I hope so.. I am thinking the pressure test should get her to leak.
72Gran
- Jan 25, 2009
- 15 Apex XTX
I was thinking internal on the turbo. If there is a crack in the coolant passage? Typically an external leak leaves some evidence especially in the snow.
How do find that? But wouldn't it loose coolant all day , why 70 miles?
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
Did you check the oil level to make sure it's not getting into the oil somehow.
Sure did!! I posted that in my info.
- Status
- 36K
