JUST PICKED UP AN 06 ER
JERSEYJOE
KEARNY, NEW JERSEY
OK I just picked up an 06 Apex ER from a friend. Has 5000 miles and needs a few things, 4 idler wheels, one rear wheel, drive axle bearing, and A Arm bushings.
What worries me is that the A arm bushings are badly worn as expected and I want to install Brass ones like I did on my 06 GT. I am concerned that the plastic bushings are worm severe enough to damage the bulkhead as in Egg shaping the holes. What is the chance that this has already happened?
If they are egged out install with some loctite quick metal. That will take up the slack if they aren't too bad.
I changed mine at 5500miles. I used oilites from Bender. They were very tight, had to use a socket to tap most of them in. 9400mi now and still perfect. I'm trying to hit the 10000 mi mark this year on my 06 ER.
Put my saver kit on and you will never ever wear out a bulkhead bushing.;)!
I didn't get to change mine until 8000 miles and the Oilites went in fine so you should be good to go at only 5500.
