earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
cheaper, easier to install, and more reliable
Fast
- Sep 25, 2018
why don't you just install hurricane's quite ring and be done with itThe only thing the "kockout kit" managed to do for me was knock $60 out of my wallet.
It has failed twice.
I will remove it from the crank, again, and put it on my bench to use as a spacer in my press.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I was hoping the $50 kit would work. It was a gamble I know, and one I lost.why don't you just install hurricane's quite ring and be done with it
The clutch rattle doesn't bother me enough to spend $329 on the Hurricane quite ring.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I am glad I didn't jump on this right away like some others things I have purchased for mine. It appears that it is just...
Check your rollers!Well I only have roughly 40 mi on this but its still in place (no locktite either) . Not sure if I should just remove it or leave it in. I think the rattle Im hearing is my clutch weights as it only happens at idle
I have had the Hurricane noise reduction shaft on my sled since new with no issues and it is quieter then all the other SWs in our group or any other one I have encountered. One of the bonuses I have noticed with the Hurricane shaft is that my primary clutch and components are not wearing at all and are maintaining like new tolerances.
I haven't got enough miles on as this winter hasn't been good.
I've put this on about 10-12 other machines so far, and positive feed back so far, but again not huge miles.
The logic certainly makes sense in that if there is grease on the splines it will reduce metal to metal contact.
I can't emphasize enough to make sure to properly loctite it in.
Also, don't expect to put it on a worn clutch and have all the noise go away. Won't happen.
Therefore, my only concern will be will the loctite let go with miles and let the ring push out...?
Time will tell.
Time will tell.
I have no doubt that it works Bob, but I just hate adding any weight if I don't have to. It's not cheap either.I have had the Hurricane noise reduction shaft on my sled since new with no issues and it is quieter then all the other SWs in our group or any other one I have encountered. One of the bonuses I have noticed with the Hurricane shaft is that my primary clutch and components are not wearing at all and are maintaining like new tolerances.
He should cut his price in half and would sell a shitt pile of them!!I have no doubt that it works Bob, but I just hate adding any weight if I don't have to. It's not cheap either.
I recently had difficulty removing a stub shaft. Once it did come, there was a surprising amount of rust on the splines.
It's really to bad Yamaha hadn't routed an oil passage to feed this area with a steady flow of oil.
If they had, this thread probably wouldn't exist.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
ya wish they would have said to locktite it in the instructions. Mine pressed in and there’s no way I can see to get it out being a blind hole.I haven't got enough miles on as this winter hasn't been good.
Time will tell.
In my case the clutch is a pro 4 billet with low miles so nothing is worn. The belt clearance adjustment on the clutch is adjusted in to proper belt to clutch clearance which drives the sheaves together which makes clearance between the weights and rollers until it starts to engage. I believe that is the rattling I’m hearing at idle. If I back the adjuster out it opens and the weights touch the rollers and there’s no rattling
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
If the noise is coming from the interference fit of the splines, I would be concerned about aeration of any oil moving through there. For the price of the noise reduction ring I think a PB80 might be a good choice for a lot of guys running stock to moderately tuned sleds.
But there isn't any oil running through there.If the noise is coming from the interference fit of the splines, I would be concerned about aeration of any oil moving through there. For the price of the noise reduction ring I think a PB80 might be a good choice for a lot of guys running stock to moderately tuned sleds.
Turboflash
- Mar 18, 2019
- Southern MN
It's physics - balance/harmonics/resonance. Unlike the "Knockout kit", what you're running actually changes (in a favorable way) the harmonics at play with the primary.I have had the Hurricane noise reduction shaft on my sled since new with no issues and it is quieter then all the other SWs in our group or any other one I have encountered. One of the bonuses I have noticed with the Hurricane shaft is that my primary clutch and components are not wearing at all and are maintaining like new tolerances.
- 43K
- 52K
