Vmax4
- Apr 18, 2003
- Orondo, WA
- 2010 FXNytro MTX 162 SE with a 270 hp MCX Turbo and assorted goodies!
I have a 10 gallon trail tank on a 2010 Nytro MTX. It seems to be leaking around the seal for the fuel pick-up. I tightened things up a bit, but still seems to leak. Any past history with these tanks? Just installed late november.
Thanks,
Steve
Thanks,
Steve
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
Sorry I can't help you. Have had 2 of them on XTX's and both have been fine. Good Luck of the fix.
new4stroker
check the gaskets. of they are off a little it can leak. I have had some come off gas cans and not even notice till your spilling fuel
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 18 Sidewinder (Wifes)
12 Nytro XTX (mine)
09Apex GT (?)
02 Viper (grass dragger)
Anyone have a tele number for Trail Tank? I need a rubber o ring from them.
yamahinn03
- Dec 28, 2004
- oshkosh, wi
12 Nytro XTX (mine)
09Apex GT (?)
Hey VMAX4 when you mounted yours how did it fit, were you able to use the washers under nuts at the mounting bolts? Did you also have a tight fit installing pick up unit?
Vmax4
- Apr 18, 2003
- Orondo, WA
I think it was the one of the copper washers. Figuring it just wasn't tight enough. Tightened, wiped clean, no short term leaking............. gonna check after a ride this coming week.
snopro442
- Dec 10, 2007
- neenah wi.
- mod 08 nytro, 2-2007 phazers and a 2010 sno pro 500 speedwerx exterminator. new 2014 nytro for towing the snowcoach. 2015 Viper mpi turbo
I have both o-rings brand new I am in neenah snopro442@att.net todd
