ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Ok stock is low but you don’t need much engagement with the 35 helix angle
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Here’s a thought, if you get the QAY-70’s you can always grind a little weight off where you need too, if you get a tune in the future weld it back on.
More of my old weights have weld on them than ones that don’t, won’t hurt anything.
Turboflash
- Mar 18, 2019
- Southern MN
LOL. Most of us old-timers chuckle about this but that's how it was done back in the good ole days before the days of $300 weight sets. Glad this art is still around! I still do it all the time.Here’s a thought, if you get the QAY-70’s you can always grind a little weight off where you need too, if you get a tune in the future weld it back on.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
IKRLOL. Most of us old-timers chuckle about this but that's how it was done back in the good ole days before the days of $300 weight sets. Glad this art is still around! I still do it all the time.
I have been kicking around the idea of some welded up 8bu-00’s in my 4 arm for some time!
Because most guys at 250lbs are on 2 or even 3 on the torsions and cranked up the stock 135# spring so far it bags out. Being coupled sled the center spring will help the rear and vice versa so you could see if the center spring is all you need but I think after you break in the suspension you are going to also want the heavier Torsions.I know less then nothing about shock springs so I have to ask why the 2704-229 is a good spring for me
Here is the latest chart I have from Cat. 2019
137" Sidewinder Torsions= 2704-026,027
SRX Torsions=3704-380,381
Recommended for 300# Rider=1704-576,577
*Note the coil springs on this sheet are for rear shock on 141" and up
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I’m 300-320 with a 17 ltx le. I run 160lb stingray in the center and one rear spring on 2 and one on 3, and I ride the piss out of that thing and it rides great.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I have the dalton teal and its a 3600 rpm engagement coupled with dalton weights and stock rollers.The Dalton teal will get you the Highest engagement of the Dalton springs.
If your plan is a tune later on the QAY-70’s will be ok with most stock muffler tunes.
Some guys have been able to run the 70’s on stock tune but they will be close to empty.
Thats good advice. But he asked. Winder_506 why do you think you will need to set the springs all the way stiff? Is it sitting on the blocks already?I’m 300-320 with a 17 ltx le. I run 160lb stingray in the center and one rear spring on 2 and one on 3, and I ride the piss out of that thing and it rides great.
Winder_506
- Dec 21, 2012
- New Brunswick
- 2005 rx warrior
2013 apex xtx with woodys power up kit clutch work and mbrp pipe
I’m just going off how I always had to have my apex set. On full stiff on the rear springs, if not it bottomed our way to much and I could never get much transfer being set on #3 all the time. I want to be able to have the rear softer and have the option to stiffen the springs. If that makes sense.Thats good advice. But he asked. Winder_506 why do you think you will need to set the springs all the way stiff? Is it sitting on the blocks already?
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
This sled is the first one I could ride “out of the box”. Always in the past I would need springs and or revalue shocks. I think you’ll be surprised how it handles the weight
Fast
- Sep 25, 2018
Does it come with the helper leafThis might work there for 300-400lbs
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Turn upside down and please don’t use arctic cat springs on a Yamaha because it’s not a cat.
That's uncalled for. You have been warned!Turn upside down and please don’t use arctic cat springs on a Yamaha because it’s not a cat.
Winder_506
- Dec 21, 2012
- New Brunswick
- 2005 rx warrior
How is the transfer in the skid with the back turned up on 2/3 ? Does it come out of the hole good and hook ?I’m 300-320 with a 17 ltx le. I run 160lb stingray in the center and one rear spring on 2 and one on 3, and I ride the piss out of that thing and it rides great.
