jagger2014
- May 1, 2015
- newfoundland
- 2018 rtx se
say I were to install a water temp gauge  on a 2011 apex xtx....and I screwed the probe into the thermostat housing where the temp light switch is..... well it work....or  well it cause the engine light to come on or give code of some sort
Tap a new port in that area?
		Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
 '07 Phazer FX (gone)
 '09 Phazer GT (gone)
 '10 Nytro FX (son's)
- Greely, ON Canada
If you could tap a new port in there, sure.  You wouldn't want to remove the stock one.  It's not just an idiot light switch.  It's a temp sensor used for the ECU which controls fuelling and will also shut down your engine if it does overheat.
			jagger2014
- May 1, 2015
- newfoundland
- 2018 rtx se
......that's what I was thinking....If you could tap a new port in there, sure. You wouldn't want to remove the stock one. It's not just an idiot light switch. It's a temp sensor used for the ECU which controls fuelling and will also shut down your engine if it does overheat.
		kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I think Ulmer has a nice little aluminum hose adapter where you cut the hose and insert this into it hose clamp each side, then screw in your temp sensor for your gauge.  Works great!
		Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
I had already pointed him to a similar adapter on Amazon.
https://ty4stroke.com/threads/temperature-sensor-adapter.160521/#post-1529737
Are you aware that you can pull up the water temp through diagnostics?say I were to install a water temp gauge on a 2011 apex xtx....and I screwed the probe into the thermostat housing where the temp light switch is..... well it work....or well it cause the engine light to come on or give code of some sort
jagger2014
- May 1, 2015
- newfoundland
- 2018 rtx se
yipper ….thanks for all the info be this well be the route ill be heading in...thanks againI had already pointed him to a similar adapter on Amazon.
jagger2014
- May 1, 2015
- newfoundland
- 2018 rtx se
no I was not ….new to the apex... a lot to learn over the summer... had one ride and now put away for the season...Are you aware that you can pull up the water temp through diagnostics?
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
Really? How do you do that?Are you aware that you can pull up the water temp through diagnostics?
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
Even on an 06 apex GT? And how do you do that?Are you aware that you can pull up the water temp through diagnostics?
Hold reset and select while turning key on(kill must be on).Even on an 06 apex GT? And how do you do that?
Do not let go until dash changes.
Press again and hold for a few seconds until dash changes again.
Using the select button, repeatedly press until diagnostic mode 06 is shown, which will be coolant temp.
This isn't displayed with engine running while riding however. It would just be something you could check periodically.
