TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
So the first one I did ...that ring with the teeth is actual made into the boot. I never got my thin screw driver under properly. So the other one it came off like it should. Here’s a comparison picture.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Anyway I have one side finished. I put a little crazy glue on to hold it in place.
Hopefully this helps fellas. I left the ball joint in ...just taped it up well to make sure it didn’t get etched from sand blasting.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Black vs white.
Great job!!
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
If you replace ball joint, powder coat, glue etc, just buy the whole arm for $120 already coated and Oem, just saying, and the color you want and it won't look buggered.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
For sure, but I do my own powder coating so doesn’t really cost anything. Also in good ole Canada Yamaha like to abuse us on parts at 250 per arm so I just saved myself 500. Also I did some searching and I’m sure a guy can get replacement boots that are better quality for under 10 bucks.If you replace ball joint, powder coat, glue etc, just buy the whole arm for $120 already coated and Oem, just saying, and the color you want and it won't look buggered.
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I was thinking of powder coating my a arms and was wondering if the top ball joint on a trail sled is removable?
RAMSOMAIR
Anybody find part #s for ball joints?
JayM
- Oct 29, 2018
- Pickering, ON
- 2017 Sidewinder R-TX SE
Thanks for bringing this topic back to life, I picked up my 2017 as a new non current just this past October with 0km and already the white A-Arms were seeing rust well after 5300km's they are brutal so I want to get them coated. This will be good info.
lilrez
- Feb 7, 2016
- Near Ottawa
Nice work
- 9K
