hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I didn't remove mine I just moved it back and put blocks back on. It still couples but way more lift. Don't think it would work with the big wheel kit as its only 1/4" from the rear wheels.
RJH
Well! The lower link pivots and stops at the block, if you just move the shaft back the lower arm will pas the shaft on compression. I added 1/2" to the arm. I put a white line in This picture where I added.
I see........... you can't drill the hole any lower
hellflyer
- Dec 2, 2008
No! The lower link needs to be modded. It's not hard if you got someone to weld itI see........... you can't drill the hole any lower
Studroes144
- Oct 30, 2013
Was just thinking about this today actually! Going to try to get this done on mine this coming week. Had some real loose snow so I pulled the shaft out on mine for a week or snow for riding, then had a real hard freeze and forgot to put the bar back in before I went for a ride, scary how high it'll pull them skis, need to tone it down a bit
