thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I speak Canadian Eh! can I get the discount. lol J/k Travis very nice of you to offer that to them. are you maybe going to do a show special price for the snow shows?
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
So I think I had the best guess out of everybody. Is there a prize ??? LOL great job ! Keep the innovation coming !!
Ya you nailed it I think it was $1,000 prize. Contact Tom he will take it from TY petty cash. JOKE!!!
Farmer 73
- Feb 20, 2015
- 2010 NYTRO RTX SE, 2012 VECTOR, 2001 SXR 600, 2001 PHAZER, 2000 PHAZER, 1983 ENTICER EXCELL III
So simple, yet brilliant!! Good job Travis! So when is the Nytro version coming out? LOL!
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
That price makes me wish I had spring ordered a 2018 Winder. Travis, this kit should be made available as a dealer installed option.
If I were a dealer, I would be eating the cost of this kit as a bonus to anyone I had sold a 2012+ Apex to. You know most of us would fall off the fence with our checkbook in hand.
Nice work!
Nice work!
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
Sorry, but I will not be at HayDays. Rock (yamaheater) is just going to have a table top display of the kit. I believe he teams up with Ulmer racing too. They will have some kits available to purchase.
For those going to Haydays, Ulmer Racing is in booth SCN20
And here is a link to the official Haydays Program with map of the vendors and events. (I hope this is ok to post here)
https://mspninc.com/pubs/Haydays/2017-Haydays/html5.html
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Looks interesting.....If the brackets rub against the spindle at that slot, I would assume the powder coat is gonna chip away. Just wondering how the test mule did as far as rubbing there.
Simple idea for better leverage, you would think Cat would have just made the spindles with a tad longer throw on their design.
Dan
Dan
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
Will there be a discount at the show?
It would be my only reason for going, haydays is a zoo.
I know this is a loaded question, but can you give a % of how much easier it is to turn?
I ride a lot of twistys in Minnesota and Wisconsin. Thats were i feel the heavy skis the most.
Thanks for designing this item, i just might keep the sled now.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I will only have a few kits available by Haydays and they will be full price.
I'm planning to offer a TY special for US buyers that purchase in my online store for a limited time in September. I will post up details soon with a discount code to enter when you check out in the store. For TY members that already purchased I will issue you a refund.
I'm looking into getting a spring scale to try and measure the tensile force it takes to turn handlebar. I have 2 identical vipers in shop now so figured I could measure each one and compare. This would just be a static test, but could be one way to try and put a numerical value to the difference is makes.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Dan
The slot in the arm is a rather tight tolerance and may even require use of a mallet to tap it onto the web. The spindles are cast, so tolerances will vary from one to next. A tight fit with no side to side play will keep coating damage minimal.
zx4ever
- Apr 14, 2011
- Northern BC canada
- 08 nytro ty4stroke customized
I bet you won't even need the bent steering rods for when you design the nytro kit might be able to use stock ones. As long as it has the 3" forward a arms. Might be a cost saving option. Keep up the good work.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Please explain the reason for the 3 holes , and when would you use the first 2 ?Here are a few photos for the thread. Check out the website for detailed info.
View attachment 129637 View attachment 129638 View attachment 129639
Bt04f250
- Mar 6, 2017
- IL
- 2018 sidewinder xtx 137 high Vis ordered 2012 Polaris rush pro r Le
3 holes give you 3 different levels of assist. The closer to stock location the least amount of steering assistance. My guess is he is offering 3 different locations so the consumer can choose which option works the best for them.Please explain the reason for the 3 holes , and when would you use the first 2 ?
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
If something was to break in the notch spindle support , is the sled driveable in the stock position , with the bent steering arms ?The slot in the arm is a rather tight tolerance and may even require use of a mallet to tap it onto the web. The spindles are cast, so tolerances will vary from one to next. A tight fit with no side to play will keep coating damage minimal.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Adjustable shocks is a big perk now days. Most consumers like to adjust and tinker, so I figured I'd offer the same. Most will probably opt for the easiest setting, but the option to experiment with 3 settings will intrigue many.
If you don't run the easiest setting you also will not compromise turning radius as much either. This could be a perk to off trail guys that can't sacrifice much increase in turning radius, but still want lighter steering when trail riding to the play areas.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
It's certainly going to take substantial force other than normal steering force for the failure you describe to occur. So.... lets envision the MPS arm takes a side impact from another sled. The MPS arm will pivot on the mounting bolt and either bend or shear the web off the spindle. Both of these results would likely spare the main ear and allow it to remain in tact, so therefore you would still be to attach the tie rod. Now your ski alignment would be off, but you'd be able to get the sled back to the truck!
- 11K
