Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
5 seasons with factory bolts. Always use Nichol & torque to specs, zero issues. This year tuned sled to 270/280 & added pm, over 350miles ago. Removed bolts today, completely locked on. I assume the additional heat Is the cause?!?!
What's everyone doing to remove bolts. I'm definitely going to break one, sooner or later.
Pstn head
Start up the sled to operating temp, let cool a little then remove the bolts. Tends to put a little heat in them.5 seasons with factory bolts. Always use Nichol & torque to specs, zero issues. This year tuned sled to 270/280 & added pm, over 350miles ago. Removed bolts today, completely locked on. I assume the additional heat Is the cause?!?!
RAMSOMAIR
Torch to the area around the bolt X6
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Now just relax! Put some heavy heat on and use a SHORT wrench. Like 1/4 drive. I find using 1/4 helps to not break bolts or prevent over torque stuff. Breath!
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Strange. I’ve run the stock bolts for lots of kms. Put them on and off with the dewalt gun. No anti seize. Haven’t had an issue since 2017.
Turboflash
- Mar 18, 2019
- Southern MN
Factory torque spec is like 18 ft lbs. Many sleds I've seen guys way over-tighten them.
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
I’m not sure what metal the bolts are made of, but it’s different than most bolts. Usually with the impact gun, a bolt will keep tightening til it breaks or stretched a bit. The stock mufflerFactory torque spec is like 18 ft lbs. Many sleds I've seen guys way over-tighten them.
Bolts just stop when they are tight.
- 8K
- 47K
