SRXracer
MrSled said:If I remember correctly, he beats everything he races...LMAO, Thanks
Thats the closest thing to gospel i read on here all day. HAHA!
MrSled said:My take is this...All the Yamahas at the lake kicked butt...the rest of it who cares....you had fun?? I know I did.
As far as you 136 Mono... jt is not allowed to post so he better go get his butt back to his new baby and quit bragging...K, If I remember correctly, he beats everything he races...LMAO, Thanks
For the record I've lost more races then I've won over the years. As far as Eric "srxracer" saying
I find that funny. Number one he is a new memeber and number 2 this is the first I've posted on the site in 2 months.Thats the closest thing to gospel i read on here all day. HAHA!
I'm also the most gracious loser. I'll be the first to shake your hand and say good job when i get beat which is often.
Anyway on Tom's advice this is the last post I'll ask John to make on this topic.
As I continue testing I'll have him post the updates.
SRXracer
take it easy there JT, just poking you in the ribs a little bit.
As far as being a new member? I've been around under this screen name since before there even was a totallyamaha site. I remeber when the only thing we had on the net was amsnow. I can't help it when accounts get reset and you lose your post count.
welterracer
11,000 rpms..????
Ive got 1130 miles on my Gt and i only pull about 10,200 on hard pack when nailing it from any speed above 50mph.. From a dead stop it will pull 10,500 and drop to 10,200!
Why are some sleds pulling more RPMS than others!
SledFreak
- Feb 7, 2005
- Ontario. Canada
You may want to adjust your weights to go to 10,500. With the amount of miles on your sled, you could try it. It would help a bit. I believe the other ones may just be a stronger motor.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Stronger motor maybe?? I only have 250 miles and am seeing 11k very quickly and it stays. This motor on my Attak definately revs quicker and higher than either motor in my RX-1 and Warriorwelterracer said:11,000 rpms..????
SRXracer
I was seeing pretty high rpm's also, like 10,800. I took some 100 grit to the clutches and it seemed to help pull it down 2-300. I think maybe i was getting some belt slippage.
