LEE337
The hole was drilled and tapped up through the bottom between the two factory bushings. The greese zerk is a 90 degree with 1/4 - 28 thread. The bottom hole you now created needs to be plugged by pressing in a small ball bearing or weld it back shut.
I tried it out once i got the spindles and skis back in and it pushed through the grease just like i wanted. Hopefully this will help all these pasrts last longer.
LEE337
LEE337
That is awesome!Black tunnel would be awesome if you could do that.
LEE337
Thanks! My thoguhts exactly! Definitely can do that but it think it will be next years project.
LEE337
Anybody ever Line-x a tunnel? I got a buddy who does it could get it done cheap. Thoughts? Add too much weight? Look good or stupid?
3wheelerdude
- Jan 6, 2010
- Ottawa Ontario
- 2019 Voyageur 600
2019 ZR200
1991 Ovation 340
1986 XLV 540
Previous sleds: 1996 Vmax600, 2007 Phazer, 2016 Bearcat 3000
Regarding cutting the track: What type of blade did you use?
LEE337
Just a normal coarse table saw blade. Not sure the details other then that.
LEE337
xt_gt
might as well do it while it's apart.
looking good.
looking good.
LEE337
Thanks got the track installed last night and the rear skid sitting in there. Hopefully will find time to work on it the next couple nights.
I like grease fittings.Everywhere possible.Shame manufacturers got away from that practice.
LEE337
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
Lookin' good! My rails are currently getting PC'd black at the moment. I have a good idea how it will look when its done, thanks to your pics. Do you have any more?
spike337
Really nice work! How do the handle bars Skinz work compared to the little gay stock ones?
