chaleurphantom
- Oct 5, 2009
- Northern New Brunswick, Canada
- 2018 SIDEWINDER LTX-LE 50th Anniversary
2016 VIPER XTX LE - WHITE,
2009 VENTURE GT,
1995 POLARIS INDY 500,
1984 SKI-DOO CITATION 3500
My latest clutch kit is dalton primary weights, usually black/green spring depends on engagement desired. Black/orange Dalton spring wound at 6-1.
Works awesome, great top end, not much heat, no blown belts we raced 1000 feet back to back to back all weekend at 285HP on TD max spool (see video).
My sled had STM clutches as we wanted to compare performance. Mine was the quickest but it was due to best traction. There was a TCat with full STM clutches and it was not quicker.
Mike had the TD clutch kit and overall was the 2nd quickest out of 4 in the group in my opinion. Again he hooked best after my sled.
SO power wise all sleds were the same clutch wise all ran very similar (2 TD clutch kits stock clutches, 2 STM setups). My cat had the best track and stud setup for ice racing so that's what gave it the edge.
What are you running for Helix? Would you suggest a different Helix from say Stock to tuned?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
What should I use ? I've got TD powertrail tune with dalton weights, was wanting to try the 33/35 with orange black spring. But Dan ur saying don't bother ?? I blew one belt at 400 miles, now I'm at 1000 and cringe every time I hit the throttle
I believe it's the 8 Jp and ya black starting to come out the clutch vents. I'm so scared of blowing another belt, never blew a blelt like on a SW so violent!
Have you checked your offset?
I believe dan is not running daltons but stms'?
FYI check your primary and secondary rollers carefully...
which daltons and loaded at?
Id try the stock helix with your O/B dalton wrapped at 3-3 pending your details..and stock 35 helix for the trail works great IMHO
Sidewinder Slayer
- Dec 30, 2014
- 2007 apex rtx
2007 phazer
2017 sidewinder ltx le
I've got ur powertrail tune, turbo force pipe, dalton weights, and updated rollers u sent me. stock helix, and both stock springs.What are you running for Helix? Would you suggest a different Helix from say Stock to tuned?
Sidewinder Slayer
- Dec 30, 2014
- 2007 apex rtx
2007 phazer
I've got the updated rollers from TD,Have you checked your offset?
The dalton weights are from TD loaded with the biggest slug and I'm my rpms are 8800 -8900
Sidewinder Slayer
- Dec 30, 2014
- 2007 apex rtx
2007 phazer
Can u PM me at kevinkovac@hotmail.comWhat are you running for Helix? Would you suggest a different Helix from say Stock to tuned?
The internet isn't the greatest here
Sidewinder Slayer
- Dec 30, 2014
- 2007 apex rtx
2007 phazer
Sorry chaleurphantom wrong personI've got ur powertrail tune, turbo force pipe, dalton weights, and updated rollers u sent me. stock helix, and both stock springs.
WinterWolf
- Mar 25, 2017
- Connecticut
Maybe somebody could answer this question.
Stock Primary clutch, and Dalton B/O Secondary Spring, with Dalton 33/35 Helix, set at 3-3 and my top end Revs are 8550-8600. If I set it to 6-1 like Dale recommends(as LTXJoe did) will this increase my top end RPM's a bit??
Joe mentioned he had the same set up, and his top end speed increased quite a bit when he switched the wrap to 6-1. He was quite low at 8300 RPM's on the top end when he was at 3-3, and then when he changed to 6-1 his top speed increased quite a bit, so Imagine his top end RPM's had to have increased as well. Am I looking at this correctly??
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
I'll chime in here with my thoughts on your questions. With your current clutching set up you're running a little low on your target rpms. A long time clutch tuning rule is to use your primary clutch to control top rpms and not your secondary clutch.
You'll probably gain a slight top rpm gain increasing the wrap on your secondary spring from your current setting of 3-3 to the 6-1 setting that seems to be the recommended setting for your Dalton B/O spring but probably not enough to get you where you want to be.
I would go ahead and set your wrap to the 6-1 setting like you mentioned doing and consider taking your stock weights out of the clutch and replacing the rivet on each weight near the tip of the weight with a lighter rivet to get your top end rpms where they need to be. It's going to take a little more time/effort to do this but it should be the easiest/cheapest route for you to get where you need to be without the added cost of going to the easy to tune and more expensive aftermarket weights.
It's cool to follow your clutching progress on your sled using the stock weight set up with aftermarket only secondary changes. Hopefully this helps.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
VX1R is spot on, but don’t these sleds take 700 miles before they are at full power? Break-in tune in the computer? I would look into it.Maybe somebody could answer this question.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
X2A long time clutch tuning rule is to use your primary clutch to control top rpms and not your secondary clutch.
Use the primary to control RPM, the secondary to control shift.
Turbo Dynamics
- Jun 16, 2016
- Gatineau
- 2017 Yamaha Sidewinder
2014 ZR9000 turbo
- Gatineau, Quebec, Canada
- turbodynamicscanada
- YOUTUBE
- TurboDynamicscanada
I would start with a known good baseline. That spring we also recommend 6-1 to get similar torsion to the stock spring at 3-3Maybe somebody could answer this question.
Sent from my SM-N950W using Tapatalk
sledding rocks
- Feb 11, 2017
- north
- sidewinder
yesterday i got the chance to put on 75 miles of lake running on my max spool 17 td tuned sled .
primary clutch - dalton weights 79 grams
dalton primary spring /blk -grn . 3800 engagement . 2 glide washers
secondary clutch - blk /orange @ 6-1 spring or 70
dalton 35 helix , td rollers .
yamha 8j belt
this combination works great. all day rpms were 8900-9000 . clutch r cool , very little belt dust ,
yesterday ice condition were very fast and hard , the max tune is so aggressive that i was hooking so hard on the ice it pulled out over a dozen studs out the track . this tune is wicked .
with hooking this hard u would think the clutch may show some sign of belt slippage or belt dust , everything was perfect , only need a new track now .
yamha 8j belt
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Why the pull outs.. Luck you didn't got that heat exchanger
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
This seems to be the overall recipe many of us are going with....albeit I will use a bit more helix.yesterday i got the chance to put on 75 miles of lake running on my max spool 17 td tuned sled .
yamha 8j belt
Nice job
Dan
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
Too long of a. Stud can do that...yesterday i got the chance to put on 75 miles of lake running on my max spool 17 td tuned sled .
yamha 8j belt
Share your log with me ID love to see. It...
- 24K
