Hey guys,
Finding it hard to steer and my carbides need to be replaced on my Slydog Powerhounds.
Any recommendations on what I should replace them with?
The site I usually order things from is RoyalDistributing since its a Canadian dealership. If the set you guys recommend are on there it would be a bonus!
Thanks again.
Thanks again.
![](/styles/vip.gif)
Shiek
carbide
tripple points from bergs tom, i used to run the shaper bars then switched to triple points which i prefer![Rockon :Rockon: :Rockon:](/styles/default/xenforo/smilies/rockon.gif)
![](/styles/TYLifeMember.gif)
Super Sled
- Feb 25, 2009
- Summit X
Re: carbide
X2, no question.
Shiek said:tripple points from bergs tom, i used to run the shaper bars then switched to triple points which i prefer![]()
X2, no question.
BombaPolaYama
Re: carbide
thanks,
Just wondering what the improvement is over the Shaper Bars?Super Sled said:Shiek said:tripple points from bergs tom, i used to run the shaper bars then switched to triple points which i prefer![]()
X2, no question.
thanks,
Super Sled
- Feb 25, 2009
- Summit X
There is always a carbide cutting tip angled down, even through turns, when a single tip carbide is angled at more of a 45 degree angle out.
kinger
Shaper bars are junk on my powderhounds went through 4 bars each time this happened within 300 miles:
I run sno studs double downs now they are beefy but like any dual push in the corners. They made it a dream to steer and zero darting so I can live with the push. Next year I may get a set of tripple points and run one double on the right side and one single on the left side.
That way if I can get some bite when I need to pass someone on the INSIDE of a corner I got the triple point biting, going to the left or outside of the corner I can push a little bit to miss a sled but still keep it out of the woods.
![utf-8BSU1HMDAxNDktMjAxMTAxMDktMTQyMC5qcGc.jpg](/proxy.php?image=http%3A%2F%2Fi582.photobucket.com%2Falbums%2Fss263%2Fkinger_photo%2Futf-8BSU1HMDAxNDktMjAxMTAxMDktMTQyMC5qcGc.jpg&hash=724a2cc75030b65dd98102bcb8592cb6)
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Bergy Triple Points, probibly be the last set of carbides you will need to buy for those skies! 2000+ miles on mine in less than ideal conditions and they are barely wore and will STILL turn on pavement/concrete.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
blueironranger said:Bergy Triple Points, probibly be the last set of carbides you will need to buy for those skies! 2000+ miles on mine in less than ideal conditions and they are barely wore and will STILL turn on pavement/concrete.
Info like your's is what sold me on a set, just wish I had enough snow around these parts to try them out!
![Banghead :o| :o|](/styles/default/xenforo/smilies/banghead.gif)
VectorLTX2012
kinger said:I run sno studs double downs now they are beefy but like any dual push in the corners. They made it a dream to steer and zero darting so I can live with the push. Next year I may get a set of tripple points and run one double on the right side and one single on the left side.
Sounds like you need to slow down or run sno cross!
Chester
![Jump :jump: :jump:](/styles/default/xenforo/smilies/jump.gif)
![Letitsnow :letsnow: :letsnow:](/styles/default/xenforo/smilies/letitsnow.gif)
Thanks for the reply guys!
Looks like ill be running these.
What size would you all recommend?
4" 6" or 8"?
4" 6" or 8"?
MikeWalters
Jeez I put on the 6" Shaper bars & it was night/day difference from stock.
2 years still look good. No trails, just ditches & fields. Guess it all depends where/how you ride.
2BLUE4U
Bergstrom 8" triple points with ski savers and add shims wherever he tells you to...you wont be disappointed and it will be the last set you buy.
