snopro442
- Dec 10, 2007
- neenah wi.
- mod 08 nytro, 2-2007 phazers and a 2010 sno pro 500 speedwerx exterminator. new 2014 nytro for towing the snowcoach. 2015 Viper mpi turbo
I am replacing the front subframe and I need to get the expandable nuts that go into the subframe to bolt the skid plate to. I cant reuse the old ones so any help would be great thanks.
iwillwait4u
- Aug 30, 2011
- Churdan, Iowa
- 13 xtx nytro stage 1 turbo
I bought what I think is called a nut cert. You can find them at Menards home depot ect. They are with the rivet guns. It is like a rivet but allows you to thread a bolt in the center of the rivet. They work great!
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Nutserts can be a problem over time. They can loosen and eventually spin in the frame so I stay away from them if possible. Speed nuts work well and can be found at most hardware or auto parts stores. http://www.dormanproducts.com/c-642-speed-nuts.aspx
Mountaintech
U nuts are the best solution.
nytrolabrador
you can buy the kit from yamaha part# SMA8FA34MTKT
ALuCsRED
grizztracks said:Nutserts can be a problem over time. They can loosen and eventually spin in the frame so I stay away from them if possible. Speed nuts work well and can be found at most hardware or auto parts stores. http://www.dormanproducts.com/c-642-speed-nuts.aspx
x2
herndonp
ALuCsRED said:grizztracks said:Nutserts can be a problem over time. They can loosen and eventually spin in the frame so I stay away from them if possible. Speed nuts work well and can be found at most hardware or auto parts stores. http://www.dormanproducts.com/c-642-speed-nuts.aspx
x2
X3 original nutserts vibrated loose after 900 miles. I finally got them out and put in speed nuts I picked up at an auto parts place in the blister packs.
Pete
