earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Higher pitch? Yes, but higher than the Ice Storm which is what I was comparing it too, then no. Although the Ice Cobra 1.6 does come in a 2.52 pitch, it is also offered in 2.86 so again same as this one.
2.86 or 2.52 is the drive pitch. Pitch can be used to describe many things but in this case pitch means the distance between repeating patterns in the lugs. This track has a 12 pitch pattern, meaning the lug pattern only repeats starting on 13th set of lugs. The longer the pattern, the more unique scratch lines you will put down. Couple this with the number of studs per bar and you have a lot of scratch lines (80). If you are installing regular studs and making up your own pattern then you can exceed this but for a pre-studded track, this is very dense.
I had no idea what they meant by pitch BTW, I had to stare at their page to let it sink in. Its just one more piece of data that camso doesn't normally share.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
$1300??????? Yikes!!!!
RAMSOMAIR
Yep, I’ll stick to the Rip II
" Starting at $1799.00 " Cdn
ouch! and people wonder why i buy off brand tracks some times." Starting at $1799.00 " Cdn
Fast
- Sep 25, 2018
That's crazy the storm 150 was $529 u.s back in 2019" Starting at $1799.00 " Cdn
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX
2018 High Country 9000
2001 SRX 700
I was going to order a Cobra 1.352 for the 2025 SRX, but when I saw this one, cool. That one with more rigid lugs should have more traction. The only drawback I think of is maybe a little less top speed and less sliding in corners... I think I will give it a try.
acpantera
- Sep 25, 2004
- W.N.Y.
- 22 TCAT+ATAC+EPS
When they say 75% the studs are are angled forward, does that mean they are pointing forward when on the ground providing more studs for braking? Or the other way around?
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
I was wondering that myself and just sent another email to camso.When they say 75% the studs are are angled forward, does that mean they are pointing forward when on the ground providing more studs for braking? Or the other way around?
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX
2001 SRX 700
I was also wondering the same thing but if you look at the video they did, look like 75% of lugs are in the direction for helping traction wich is perfect imo.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
I think it is just a cultural and english translation thing. I think they mean forward (with a quebec accent) as in 'into the ice' whereas most people would describe the orientation as backward, away from the direction of travel. Or forward looking at the top of the track which of course means backward if you focus on the part that meets the ice.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
And their response is that yes, 75% of the studs/lugs are at a 15 deg angle to assist in forward acceleration and 25% are angled to assist in braking.
In both cases the lugs are designed so that under acceleration/braking forces they flex back to neutral ( 0 deg) for max penetration.
I suggested flipping the pictures around but they state that the pictures are just to show the 15 deg lean. Below still makes more sense to line up with their text (75% are angled forward, 25% are angle backwards)
acpantera
- Sep 25, 2004
- W.N.Y.
- 22 TCAT+ATAC+EPS
Durometer?
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Durometer?
They have never directly responded to that question in an email, they have at tradeshows.
viperaddict
- Sep 6, 2004
- Alton NH
- 2003 viper w/monoshock and simmons skis
2011 apex SE
I like the looks of it and the concept, but it appears it wouldn't fit my 2011 apex with the 2.86 pitch. And the price is STEEP! Maybe both of those things will change in time. It isn't on the tracks usa site yet and they are always cheaper than the msrp listed
- 13K
