new drive shaft axle?
It seems like a bearing with a cocentric locking collar could solve these issues while still allowing for easy disassembly.... although due to the brake caliper location, the locking collar side of the bearing made need to be on the inside of the tunnel, not against the brake rotor.
https://www.timken.com/products/timken-engineered-bearings/housed-units/concentric-locking-collar/
ok so i just looked at the official iso guide to bearing fits and the shaft should not be less than .0005 of the bearing diameter!!!so if the shaft is .001 under theres going to be trouble.
I had the BOP wedge for 5000kms and pulled it out to see ZERO wear on my driveshaft. This worked for me! Bearing was still good too. Now have 11,000kms on machine and driveshaft still looks great!
Thats what we want to hear! How many foot lbs did you torque it?
Before you put this on was the bearing spinning?
Thats what I meant before. Many including the brand new 2020 shaft I got are not even close!
I think "twyztid" is on to something here. For decades Yamaha has used a concentric bearing with a locking collar on the driveshaft bearing and the jackshaft bearing. Has anyone ever heard of the bearing spinning on either shaft with this set up?
With the concentric bearing you've got a lot more surface area to make contact with the shaft along with locking it down to the shaft.
I'm sure that the Arctic bean counters have a lot to say in what components they use. It's too bad Yamaha doesn't step up to the plate with this seemingly tried and true set up.
Here's a diagram of the 2020 Yamaha RS Venture and VK 540 that are the sole surviving sleds still being made by Yamaha in Japan. It's interesting that Yamaha still uses the concentric bearing and locking collar on it's sleds:
Draw your own conclusions here but I think the answer is pretty obvious.
Thoughts?
Could very well be the flex is required. Maybe the sled vibrates like a mofo is locked solid??
We also need to ask ourselves if some slip was by design. I think it was and thats why it hasnt been changed yet. Chassis Flex.
I'm not meaning to bust your ballz here Steve but let's agree to disagree....
https://dsportmag.com/the-tech/chassis-101-performance-control-safety/
I'm sure that AC and Yamaha have engineers on their staff that are on a much higher pay grade than me but it's an interesting topic to consider.
I've got some flex in my current chassis (body) but so far no slippage on my drive shaft :)
