NEW ECU
YamaSpark
Greenfield, Minnesota
2016 SR VIPER S-TX 137 DX
Is a brand new ECU from Yamaha plug and play, or does it need to be flashed by the dealer to function?
It should be plug & play I believe.
I have some good used ECU's here if you need one.
I probably should have gone with a used ECU, but a brand new, updated version ECU is currently reasonably priced, so I went new. Hopefully, it doesn't need to be programmed, since many of the Yamaha dealers in my area have closed their doors.
A search on this forum hasn't given me a solid answer on this. Has anyone replaced their ECU with a new one, and did it require dealer programming?
Thanks!
Just has to be right Part # since it is Driver size specific. Engine hrs are stored in there also.
