![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
What?new way to affix hyfax
Turboflash
- Mar 18, 2019
- Southern MN
I'm with KA. Since they didn't change to a design that locks the bearing and shaft together, nothing has changed. Same failures will keep happening. Might take longer if shaft is harder, etc but it will still happen.
Kuzzy
- Dec 6, 2020
- saskatchewan
- 2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
unless you can find something that is already splined inside and outside and cannabalize it, making interior splines is not easy, and definately not cheap. Not to say it cant be done, but I am guessing you will have a hard time finding a machine shop willing to do this for a handfull of parts. Of course just because i am saying this, (and it would be my luck) somebody will jump up and do it for you haha.Ok here is my idea on this.
I hope one of the shops can make this set up.
Make a splined sleeve for the brake disc to slide on existing drive shaft.
Must make a new brake disc to accept this.
Must also thread inside of driveshaft.
Torque the sleeve down against the inner race on bearing and be done.
Brake disc will still be able to float with this setup.
Tim
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
It would just be a new brake disc design with a tight fit on the drive axle splines.
Could even be tighten in place with BOP drive shaft wedge.
We don't have much manufacturing where I live.
I am sure it can easily be made on a milling machine. The disc and hub or sleeve.
Kuzzy
- Dec 6, 2020
- saskatchewan
2022 STX GT
2017 King Cat M9000
how do you mill a spline on an ID?It would just be a new brake disc design with a tight fit on the drive axle splines.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I am not a machinist so I dont know. How do they do it on the brake disc? Can't be too difficult.how do you mill a spline on an ID?
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Yep, thats what it says at bottom before image is cut. Can't see a difference on your '22?What?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Assuming your talking about the slides that go on the rails.. I replaced the black ones with orange, and had the full skid out on the bench.. I replaced them like I have for 30 years. Unless I missed something/ I don't see ANY changes to the skid or the rails on the 22.. I know they came off like butter and the orange went in like butter.. Nothing like working on NEW sled parts.Yep, thats what it says at bottom before image is cut. Can't see a difference on your '22?
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
They used the word hyfax other than that I have no idea. To bad the pic is cutout. We could of seen where the change is made.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Hyfax and slides are one of the same I believe. Who knowsThey used the word hyfax other than that I have no idea. To bad the pic is cutout. We could of seen where the change is made.
JMS@Yamaha
A couple clarification points here:
-Upper Drive shaft surface change was completed at start of 2022 production.
-Track drive shaft hardness change was completed at start of 2022 production.
-Upper gear with new bushing material was a running change through production.
All of the above items are continuous improvements to the vehicle and will retrofit to older models.
Please see better screenshot in English
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
The man, the myth the machine! Thanks!
Edit: Hey you cut of the hyfax part ? lol
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Please see better screenshot in EnglishView attachment 163508.
Is there a different part number to the shafts that have been changed?
If not how will we know if we are getting the latest greatest when replacing our worn shafts?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I will pull mine tonight and beat it with a hammer! See how hard it is?
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Be nice Jon. lol
I'm thinking the hyfax part doesn't apply to Sidewinders at all. Maybe '22 Snoscoots? Probably why it was cut from Jaret's and earlier screen shot.
- 40K
