I am not finding the post but to put those in even the stock aluminum skid has to be removed. Two choices either skip it or try some of those rubber expanding screws like used for hanging pictures on a wall. I know it sounds Hokey and is but they will hold the plate up and that's all they really need to do. I suspect they just aren't used at all on the newer Vipers.Thanks for explaining; I did not do the cut out, but I would like to use the screws. Is there a Yamaha part number, or specs for what I need to replace the missing screw?
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
I had similar damage done on the Manitoba ride last year hitting a rock just off the side of the trail. That piece (look it up on microfiche) can be replaced for less than $20US. Luckily it missed the engine/oil/filter/cooler. But a replacement part, a few rivets and a couple of beers, you will be good as new.Looking for a skid plate myself. This happened going over the rocky shore line from my cabin to the lake in low snow conditions at about 1 mph. The rock must have pushed up the access door and hooked at the back instead of sliding off . OEM pan is very very light aluminum.
Wannaviper
- Mar 18, 2014
- West Gardiner, Maine
I am a little confused, but unforuntately that is normal for me! In looking at the rear skid plate I installed, there are two holes in the plate that line up (almost) perfectly with two holes that are already in the aluminum skid plate. It is hard to see to be sure, but it looks like the holes are threaded for a bolt rather than for a sheet metal screw. I am assuming that those are the holes that the skid plate instructions tell me to reuse the existing screws?I am not finding the post but to put those in even the stock aluminum skid has to be removed. Two choices either skip it or try some of those rubber expanding screws like used for hanging pictures on a wall. I know it sounds Hokey and is but they will hold the plate up and that's all they really need to do. I suspect they just aren't used at all on the newer Vipers.
Wannaviper
- Mar 18, 2014
Ouch! I never got around to putting the skid plate on my LTX DX because I wasn't really doing any "off trail" riding, but seeing your picture, I am thinking that the skid plate is pretty cheap insurance for any Viper, even though it is a pain to put on! Sorry it happend, but thanks for posting it as a warning to us all.Looking for a skid plate myself. This happened going over the rocky shore line from my cabin to the lake in low snow conditions at about 1 mph. The rock must have pushed up the access door and hooked at the back instead of sliding off . OEM pan is very very light aluminum.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Turtle- I remember that ROCKet ride, those of us behind you could not figure out how you got the sled pointed and moving toward the sky..........now that all is well it is even funnier.
Maybe yours are? I looked and others don't.I am a little confused, but unforuntately that is normal for me! In looking at the rear skid plate I installed, there are two holes in the plate that line up (almost) perfectly with two holes that are already in the aluminum skid plate. It is hard to see to be sure, but it looks like the holes are threaded for a bolt rather than for a sheet metal screw. I am assuming that those are the holes that the skid plate instructions tell me to reuse the existing screws?
Wannaviper
- Mar 18, 2014
I will crawl under and take another look tomorrow with my flashlight; hopefully it is a threaded hole and I will be able to figure out what size bolt fits. I am assuming it is most likely metric? As always, you have a world of knowledge about the Vipers, and you have helped me to understand and learn about my sled. Thanks again!Maybe yours are? I looked and others don't.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
If you want good protection and easy removal for oil changes check out the one I offer. 3/16" aluminum.
http://www.barnofparts.com/skid-plates-new
I will check screw size when I get home. Happen to have my old subframe in shop.I will crawl under and take another look tomorrow with my flashlight; hopefully it is a threaded hole and I will be able to figure out what size bolt fits. I am assuming it is most likely metric? As always, you have a world of knowledge about the Vipers, and you have helped me to understand and learn about my sled. Thanks again!
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
Now that I like.
Does the kit come with all necessary fasteners?
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Now that I like.
Hey that sled looks familiar...
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
Thanks for the pm reply. Just ordered one up. Merry Christmas to me!
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
How do I order this if I want it powder coated? I would like to get one.
M5x.75 is the bolt size
Robinmaine
- Apr 26, 2015
- Sabattus
- 18 SR Viper LTX
If your talking about the screws that are parallel to the front screws to the access panel they are threaded, but the screws that come with the skid plate screw right in. I did my plate 2 weeks ago. I hope this helps.
