Nyper build thread
Just an fyi for you I found my old nytro rad and fan with plastic shroud on it and weighed it at 4lb 2 oz. Filled with water it is 5 lb 2oz. I think you got it figured now anyway. Just wanted to document those numbers on your thread
That would work good for version 2.0, I’d have to see what the engine placement looked like. I moved the engine towards to the chaincase as much as I could on this build to keep it narrow.
I did one last order for Ti bolts from Race Ti in the UK today. Got the rest of the bolts I’ve been wanting. 8mm upper a-arm bolts, 8mm shock bolts, 8mm inner tie rod bolts & nuts, 8mm engine mount & starter bolts, 8mm steering post bushing bolts and a couple other things.
Installed the drivers tonight. Flipped them around from how I ran them last time so the new side of the teeth would be driving the track. Also swapped them side for side so the one that was in exhaust last time wouldn’t be this time.
Design flaw. I thought I had measured everything out but clearly was off somewhere.
That was with the drivers centered in the windows. I needed about 1/4” more total. I pressed each driver inward another 1/8” and then cut 1/8” of plastic off.
Because of how tight everything is, I have to install the driveshaft first and then the chaincase.
Hope to the have rear suspension in tomorrow night.
If I ever finish this thing I’ll eventually get the newer style drivers. Seems like that would be less strain on the track windows.
What are you doing for wiring? I have some ideas for solid state relay and a Amplink PDM if you need some ideas.
I honestly have not put much thought into it. I have the gutted harness from my original sled that was pretty stripped down but it had a lot of splices. I have another factory harness and my plan was to gut it same as the original but do a cleaner job.
I can put more thoughts down later today but around power what are you thinking for relay fuses etc? Is the stock ECU heavy, wiring heavy? My build I’ll probably use a MaxxEcu mini for weight savings and amazing capabilities. Might even pony up for tefzel wiring. Compared to my apex oem wiring I’ll save around 15 lbs! Crazy!
