bpatton74
- Nov 11, 2014
- Skowhegan Maine
- 2017 Arctic Cat XF9000 Cross Country
Has anyone tried the dyno-tab octane booster? Just looking at them because of the ease of carrying them on the sled.
For background I have the the Hurricane 225/240/270 flash with the 3 bar sensor and GFB blow off valve. I am getting alarms at about 8200/8300 rpm from the knock sensor. I've already taken care of the clamps on the throttle body/head. I have not tried any octane boosters yet. Not sure if I'm getting crap 91 octane fuel or not...
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Never tried the tabs. Could be bad fuel. Could be a tired fuel pump?
bpatton74
- Nov 11, 2014
- Skowhegan Maine
I read about the fuel pump, knock sensor, air leaks, and bad fuel.... Who knows, almost regretting doing the reflash at this point... Ran great before the flash.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
The engine should not be lugged down at 8200 and 8300 RPM. Get it up closer to 8900.
bpatton74
- Nov 11, 2014
- Skowhegan Maine
That's just it, at 8300 rpm the knock sensor is flashing. Do you think I should remove some weight off the primary?The engine should not be lugged down at 8200 and 8300 RPM. Get it up closer to 8900.
KnappAttack
- Feb 19, 2004
- Welch MN
Yes. What is the clutch set up and tune HP you are trying to run?
bpatton74
- Nov 11, 2014
- Skowhegan Maine
I am attempting to tune for the 270hp. I have the BMP Stage 2 kit , 68-90 gram I also have the torsional conversion set in the middle hole. The current weight set up is 3 3 2 2 which is 82 grams.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
I would pull some weight to get rpms higher I struggle with similar problems. I’m currently at 76.6 on DTAY-1 ‘s. Hope that does it for you it’s a very frustrating problem
bpatton74
- Nov 11, 2014
- Skowhegan Maine
It is!! I've sunk so much $$$ into this thing hopefully I can get it straightened out tomorrow.
Erskin
- Feb 6, 2021
- Maine
- 2021 Thundercat
265 maxspool TD SM
- Bangor
I think 82 grams is too much, I would start closer to 78.
bpatton74
- Nov 11, 2014
- Skowhegan Maine
So I ran it today out on the lake (ungroomed 4 to 6 inches) and ended up with 76.4 grams for 8800-8900 and didn't see a knock light. I might have to fine tune a little more when I actually get on a groomed trail but at least I'm in the ballpark. Thank you guys for the help.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
Good to here you made progress
Just curious what secondary spring set up are you running and what track
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
....and gearing?Good to here you made progress
bpatton74
- Nov 11, 2014
- Skowhegan Maine
I am running an 1 3/4 track with 21-41 gears. The secondary is the BMP torsional conversion, I think the spring is orange.
- 11K
