viper strike
- Dec 22, 2016
- belle plaine mn
- 2015 yamaha sr viper ltx dx
So when i installed the osp belt deflection adjuster there was no side to side play on my secondary.
Stock configuration the secondary floats about an 1/8 inch back and forth side to side
I did remove the 2ndary and remove the three bolts and washers.
Is this normal. Or should there be float with the osp adjuster installed. Or does it sit tight on the helix face.
