viper strike
- Dec 22, 2016
- belle plaine mn
- 2015 yamaha sr viper ltx dx
So when i installed the osp belt deflection adjuster there was no side to side play on my secondary.
Stock configuration the secondary floats about an 1/8 inch back and forth side to side
I did remove the 2ndary and remove the three bolts and washers.
Is this normal. Or should there be float with the osp adjuster installed. Or does it sit tight on the helix face.
rbell14
On mine I don't feel the float but it floats once your hit throttle. I asked the same question but to get the deflection right I couldn't move it by hand. Never had any issue since and that was 2000 miles ago.
viper strike
- Dec 22, 2016
- belle plaine mn
So there is no play side to side on the secondary clutch shaft. With osp adjuster installed.On mine I don't feel the float but it floats once your hit throttle. I asked the same question but to get the deflection right I couldn't move it by hand. Never had any issue since and that was 2000 miles ago.
rbell14
That's how mine works. I can't generate any float by hand when my adjuster sets the belt with the correct deflection. I had OSP look at it while I was at their shop last year.
I think you have float, just can't manipulate it by hand. Once riding it will float.
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
With the right belt deflection set on the adjuster You only get float once the clutch starts to shift. When shut off there is no float.
I have used one for over 13000 km On my sled and no problems.
klondike22
- Mar 4, 2013
- northern New York
- 15 SR Viper LTX SE
Mine has no float at rest either....I remember reading last year prior to purchase that is the case.
viper strike
- Dec 22, 2016
- belle plaine mn
Ok thanks i just wasn't sure because the way it has play in stock configuration vs no play with the belt set correctly on the 2ndary sheaves and 3 bolts removed from the backside. On the other hand i see bop upgraded there version.With the right belt deflection set on the adjuster You only get float once the clutch starts to shift. When shut off there is no float.
viper strike
- Dec 22, 2016
- belle plaine mn
Thanks just wanted to make sure.Mine has no float at rest either....I remember reading last year prior to purchase that is the case.
Because problems on the trail suck and i didn't want to start blowing belts or something stupid . sometimes stupidity hurts!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
That's the way they are designed!
No float until secondary is in motion
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
So if there is no float at initial engagement to properly align the clutches I'd think that there is a possibility of misalignment at engagement which could contribute to premature belt wear. I'm not a fan of the belt adjuster because the OEM setup works well without adding additional components. I don't see any advantage or performance gains by running it and would rather spend my money elsewhere. I guess I just don't see the need for it on these clutches.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
When adjusting belt, is it suppose to ride flush with secondary or below just a bit?
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
All I can say is I got 8500km out of an 8nd belt with the osp adjuster installed.
rbell14
Adjuster really isn't about performance IMO. It just makes it easier or quicker to adjust the belt without having to pull off the secondary and screw around with washers.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
And you can get just as good mileage on a belt without it. How often do you adjust for a belt? Once a year...... or maybe never. My Nytro has 10,000 mile on it and I might have adjusted belt deflection once several years ago.
Adjusting belt height is a performance adjustment.
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
I dont disagree with you just want to say the belt adjuster never hurt my belt aliment .
