AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
Thanks. Just listened to it. Some good info in the podcast.The podcast said it was the same 8jp with larger diameter primary.
AXR
- May 5, 2007
- Central NY
hmm interesting.I was told today 8JP length but it will be a new belt because of the different sheave angle. Until I get a parts diagram I can't confirm
From Yamaha USA Facebook:
Did you know: The Genesis 998 Turbo has 2 oil pressure sensors for low and high engine speeds. The black sensor is the low rpm sensor. It shuts off the engine when the engine is at 4400 rpm or less and senses low oil. The gray one steps down the engine incrementally if it senses low oil above 4400 rpm
Did you know: The Genesis 998 Turbo engine has an oil AND a coolant circuit just for the IHI turbo unit. Gotta keep that baby cool and safe!
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
The more you learn , the better it gets .From Yamaha USA Facebook:
I think that when I buy my Sidewinder , I will include a 15-20 % tip , just like at a restaurant !!!!!!!!!!!!!!!!!
Martens199
- Oct 1, 2012
- Saskatchewan, Canada
- 2008 Yamaha nytro 153 mcx190
2015 SRViper mtx se 162 mcx270
Isn't these oil sensors the same set up as what on the vipers?From Yamaha USA Facebook:
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
No not a high AND low sensor with rpm shut down control.
Martens199
- Oct 1, 2012
But they do have two sensors there. So how do the vipers work? Is this their fix for when the sled is in vertical situations?No not a high AND low sensor with rpm shut down control.
super_rash
- Feb 24, 2014
a lot of sensors... hmmm, here's hoping it will all work well... one bad sensor and you're shut down the way i see it...
Just like a new car. It's a real easy fix. Don't buy one.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
the motor and its sensors etc are kick #*$&@...one beautifully designed piece...if you are afraid of protection sensors you should'nt be running with the big dogs (200+ hp and boost)
any idea how the jackshaft sensor comes into play...traction control lol?
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
We
need a drain plug on the chain case!
Where does it say there is a Jackshaft sensor?the motor and its sensors etc are kick #*$&@...one beautifully designed piece...if you are afraid of protection sensors you should'nt be running with the big dogs (200+ hp and boost)
super_rash
- Feb 24, 2014
Yeah really, its just i don't take my car in northern areas 200 km from any civilization then beat it to a pulp in busted trails for 400 miles at max Revolutions , minus 25 Celcius and doubtfull gas ...so you can't really compare the two situations, but i'm sure you already new that...Just like a new car. It's a real easy fix. Don't buy one.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
oops....its driveshaft sensor...even easier for an abs application lolWhere does it say there is a Jackshaft sensor?
