razor_220
- Dec 21, 2012
- Saskatchewan
- Yamaha Nytro X-TX(sold)
Yamaha SRViper X-TX(sold)
Yamaha sidewinder B-TX
Hey guys!!? I was wondering if I purchased a used Power Command V, if i could put on myself, the sidewinder btx programming?
Or do i have to purchase a Power Command V already programmed for the sidewinder?
Fleecer
- Jun 13, 2014
- 2019 SRX
I think your money would be better invested buying a tune. $475+/- bucks will produce 50-70 more horsepower and run flawless.
Turboflash
- Mar 18, 2019
- Southern MN
I have a slightly used PC 5 I ran on my '17 Cat ZR9000 for a bit. It's plug and play. Goes into stock connectors. Also have CAI kit to go with it if you're interested.
PM if you're interested.
JayM
- Oct 29, 2018
- Pickering, ON
- 2017 Sidewinder R-TX SE
I would just get your sled flashed it's got to be much better gains than the PC.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
I have a TD Flasher and MAP bundle with Anti lag and Data logging valued over $2000. Will let go for $1200 with ECU exchange if your interested.
razor_220
- Dec 21, 2012
- Saskatchewan
Haha! don't really need more HP. just was looking to tune a bit for after market exhaust.I think your money would be better invested buying a tune. $475+/- bucks will produce 50-70 more horsepower and run flawless.
Mototown
- Sep 11, 2018
- Apex 40 th
A flasher and bundle tune is way better deal
JayM
- Oct 29, 2018
- Pickering, ON
Hands down get a tune rather than the PC for that.Haha! don't really need more HP. just was looking to tune a bit for after market exhaust.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
You dont need a tune, but once you ride your sled with a tune, youll never want to ride it stock again.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
more hp is exactly what you will get with a free flowing exhaust that's why you need a tune or a programmer like the pc 5 now I get it you already have the pcv and want to save a buck using that. I think Evo did an exhaust only with programmer for fuel adding very early on and it worked but was not as good as a re-flash to the ecu. what these meatheads are trying to say is spend the money you wont regret it at all. some cans don't require a flash or programmer so see what the manufacture recommendsHaha! don't really need more HP. just was looking to tune a bit for after market exhaust.
Give Excell and Ulmer a call. I know Excell uses a tuner with dial boost and I am sure Ulmer also could get you set up. The PCV PTI setup works very well.
- 43K
