1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Looking to find out if the computer can be flashed to talk to the eps.Have you physically done this yet or this the “this should work” stage? Just know this guy has done them and said roughly how he goes about it.
If so it would be easy to do.
The current sleds with dumb shocks and eps would be the flash to have from research.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
The only potential speedbump so far is whether or not the ECU has to initialize the EPS system. The EPS itself is largely stand-alone with just the canbus and power ground as connections. While that canbus could be used for a myriad of things, the only thing that makes sense is telemetry coming from the sled to tell it the current speed in some form and that is already on the canbus so the ECU is there for error code processing and maybe, maybe... initialization. That is all just an educated guess. The rest of the list is all physical items (bolts, brackets, steering column, etc) that are completely independent of model year.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Its only 5 wires to splice into the old harness.
$1385 in parts, us$. And need to source a couple connectors for the power steering motor.
Then flash computer to work with eps motor.
The canbus/power and ground I assume you mean. Those can all be gotten to without harness splicing since the canbus is already available on the diagnostic port and the system requires its own dedicated power. Any canbus circuit tap would work.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
All the parts are on back order also.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
It’s a standalone ecu for the ps, needs to splice to power ecm and give it signal. Besides that it’s all plug and play replacement parts
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Looks to me like the power steering motor has that built into it and talks to the sled ecm.It’s a standalone ecu for the ps, needs to splice to power ecm and give it signal. Besides that it’s all plug and play replacement parts
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
So he's saying it will automatically pick up the signals without any type of flash then?
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
From what I gather yes, but need diff parts and diff ways to splice in. I obviously don’t know the details but he seems pretty ontop of it. All I know is what I shared there
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
The dealer he is doing them for has a bunch of 23 xtx se 146 sleds that he is installing them on.
Brand new sleds.
Brand new sleds.
Farmer 73
- Feb 20, 2015
- 2010 NYTRO RTX SE, 2012 VECTOR, 2001 SXR 600, 2001 PHAZER, 2000 PHAZER, 1983 ENTICER EXCELL III
I wonder if he can make it work on a MY 2022 or newer Viper?
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
No idea. It’s possible I am sureThe dealer he is doing them for has a bunch of 23 xtx se 146 sleds that he is installing them on.
Brand new sleds.
As far as viper Idk that either. Message a Mike Duhr on Facebook that’s who is doing this.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Anyone have a non eps, dumb shock 17-19 and a eps sled that they could install ecm and cluster in eps sled and see if the eps will still work and no codes?
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
I have both of those sleds right now and will try that swap to see what happens (a 22 EPS non-smart shock sled and a 19 non-smart shock sled). They are in storage but I'm curious to see if it will work too!
- 16K
- 15K
