Buckeye
- Lakes Region, NH
Any need for a prefilter on a Turbo? I'm thinking probably not. But I don't know that much about it. Anybody have any thoughts?
Climbmax
If your riding a lot of trails and not much powder probably not. I run mostly powder and I have a pre filter. You don't want any water entering through your filter at all.
I also moved my intake on the MC kit so rather than pull air from the valve cover area, I used some large rubber tube with a 90 degree bend and relocated the intake to just behind the dash area so it is up higher and away from the head cover and all the hot air. I also removed the instrument cluster tothe hadlebars so where the dash was originally it is now screen so some fresh air will get to the intake.
Good luck.
CM
Good luck.
CM
