jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Damn that throws my theory out the window? Gotta be some kind of pattern! You stock? How many miles?Mine had never blown a belt and the belt survived this clutch failure as well
Mototown
Washer is missing beside roller.... do u guys run without washers or rollers ?
Why doesn't someone take some washers or rollers out of their clutch see how far u can get ... lol
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
He said on FB that the roller bolt fell out and he found the parts in the belly pan to put it back together and get home. Probably couldn't find the other washer. That pic doesn't have much of anything to do with the rest of this thread.Washer is missing beside roller.... do u guys run without washers or rollers ?
Alsim
- Oct 6, 2014
- LTX SE 2018
I saw in another forum with another exploded clutch. I'm a bit afraid that will my turn next time. I was wondering if someone had gave a try with a pb80 ? If it's works we eliminate rattle and will be a cheap replacement vs team's conversion clutches.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Maintain your clutch. Check your roller and weight bushings.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
- Apr 17, 2003
- Menno, SD
- Menno, SD
Alsim
- Oct 6, 2014
- LTX SE 2018
Yes for sure. I always keep an eye on them. Surely fine on stock but sometime I have a doubt on long pull at wot especially with a tune. A lot of pressure there.Maintain your clutch. Check your roller and weight bushings.
Alsim
- Oct 6, 2014
- LTX SE 2018
Thanks Ulmer for the video.
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
View attachment 144966I serviced a clutch yesterday, rollers were way beyond worn, weight bushings were out of spec. Guys are not paying attention to this stuff like they need to and this is what is causing failures. I'm not saying the clutch is perfect, I'm saying lack of service is causing many of the failures.
Put this in my archive of notes....thanks.
I just pulled mine apart this week. All looked good for now.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
2 more SW clutches blown apart this past weekend from a Wisconsin dealership.
Alsim
- Oct 6, 2014
- LTX SE 2018
Probably is the maintenance lack but also simply the clutch can't manage the winder power. I remember you showed us the little cracks near the allen screws. I didn't hear a lot of same issues with viper and Apexes primary with big HP2 more SW clutches blown apart this past weekend from a Wisconsin dealership.
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Both my clutches looked perfect with 4400 miles, I checked them over real thoroughly, had them all apart. I inspected all the rollers, bushings, pins then cleaned everything. The belt looked great too.....everything is stock. I think the original owner was an easy rider though.
We'll see how they hold up the way I ride it now.
boostfever
You gotta realize that most big power apexs and nytros were basically one off expensive builds by guys who understood the clutch maintenance required, with the ease of getting 270 hp from a sidewinder, many guys just assume they are still a turn key sled... this is not the case. Rollers and wieghts are high wear items and need to be replaced often
