2 are at .358 and 1 is at .359
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Cant say the same for mine. I have some bronze roller bushings I will be testing. I am going to look for some bronze for the weights also.
What do you run for primary weights?Cant say the same for mine. I have some bronze roller bushings I will be testing. I am going to look for some bronze for the weights also.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
G-force, but they use the stock Yamaha bushing. The bushings where not new this year, probably 2500 miles. I just installed some bronze bushings that I also got from G-force.. I may order some other bronze bushings to test also for the weights.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
A stock Sidewinder came in for clutching and the clutch is cracked on 2 of the clutch weight pockets thru the allen screw holes and towards the top. 1,486 miles bone stock
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Weak, good you found that for him.
Wingwong
- Mar 20, 2018
View attachment 146540 View attachment 146541 View attachment 146542
Would this be cause by over torquing
Just backed mine in the shop. Has what appears to be the same marks,( although your pics aren't real clear.) Took a rag with a bit of brake clean and wiped them off.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
WTF is going on? That is not good. Really would like to know what’s causing this? Harmonics? Over torqued set screws? What’s crazy is it’s stock ones not just boosted up ones. That’s really low miles. Any indicators from the owner of this clutch in the picture?
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Had my clutches all apart today. 5200 miles and change. They look great!! I will say the 8jp is a dirty belt. Plenty of belt dust in 800 miles. The 8DN is much cleaner.
What's not good? I don't see any cracks.WTF is going on? That is not good. Really would like to know what’s causing this? Harmonics? Over torqued set screws? What’s crazy is it’s stock ones not just boosted up ones. That’s really low miles. Any indicators from the owner of this clutch in the picture?
The threads or Allen wrench should strip before that happens. Bad design and should not have to worry about overtorque on a little set screw like that. Never did before.Would this be cause by over torquing
Would be nice to get a better picture of the cracks Terry just so we know what and where to look. Awesome you caught it before failure. Scary.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I don't see any cracks there. Dirty, but no cracks I can see there.
Byam
Put your glasses or buy a bigger IpadI don't see any cracks there. Dirty, but no cracks I can see there.
