ronzx9
- Jan 11, 2017
- Ohio
- 2017 Sidewinder L-TX-LE, 2016 Grand Touring SE 1200
I was doing some routine maintenance on the primary and I found one sticky roller. After some investigation I noticed the bushing inside the roller has shifted to one side and protrudes out past the sleeve. I tried tapping it back in and pressing with a vice but no luck. Does anyone have a trick to push it back in?
Pstn head
Get new ones, it'll happen again.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
You can push it back in with a vise as long as its not damaged, but it will just push out again at some point. New ones wont last longer either. I saw one guy who removed the bushings, sanded them with 60 grit and reinstalled the bushings with green loctite.
ronzx9
- Jan 11, 2017
- Ohio
This sucks. My dealer wants $60 each for the rollers, even he says it's BS,
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
x2 on Thunder Products
Byam
Primary roller bushing issue? Never heard about it!
What i used to instal and remove bushing. One way for roller the other for weight
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
What size are the stock rollers?
yamagone
- Dec 17, 2008
- Essex, Ont. Canada.
- 18' Sidewinder
I'm not 100% sure but 14.5mm sounds familiar.What size are the stock rollers?
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Yes 14.5I'm not 100% sure but 14.5mm sounds familiar.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Warranty, Warranty, Warranty!!!
Also bushings can be bought separately, there about $20 ea.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
I was told that clutch components are only covered for the first year. Got into it with my dealer last year because they "updated" my secondary rollers at one point but apparently those were the same as the original ones. They never informed me that a different one came out. Last winter when they flat spotted again I found out there was a different roller that I did not have but he claimed it was too late for Yamaha to cover them even though the problem started and was known within the first year.Warranty, Warranty, Warranty!!!
ronzx9
- Jan 11, 2017
- Ohio
Thanks for all the replies. I'm checking on warranty but ordering the Thunder rollers. If the dealer can warranty then I'll have spares.
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I had one do that the first year I owned it Ron and they gave me a new one under warranty.
ronzx9
- Jan 11, 2017
- Ohio
Thanks Joe. I hope it's covered but I'm not overly optimistic. You have much snow up there? I know trails don't open until after deer season, when is that this year?
