Rukus
- Dec 9, 2018
- 2017 Sidewinder XTX SE
2012 Phazer RTX
2000 Venture XL
2013 Nytro XTX
2012 Nytro XTX push turbo
I've got the last big ride of the season planned tomorrow was just looking over the clutches on my 2017 sidewinder xtx and noticed 2 of the primary clutch rollers can be rotated freely, one can not be moved at all it seems seized. There will be zero chance I can fix this before tomorrow. How bad is it to ride about 300 km like this?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Well it wouldn't be good in that it will wear the weight out if its not rolling. If the busing is actually toast, you could also swing the weight past the roller and blow the clutch up depending on the weights being used. Not a good scenario.
All is not lost however if the roller and bushing is salvageable, pull the roller out and see if its just the bushing pushed to one side, this happens often. If it's not flat spotted and the bushing still looks OK but just pushed to one side, you can push the bushing back into the center of the roller and should get the day out of it. If the bushing is shot and egg shaped or if the roller is flat spotted it wont be able to be used and need replacing.
Rukus
- Dec 9, 2018
2012 Phazer RTX
2000 Venture XL
2013 Nytro XTX
Thank you. I've got a Nytro just sitting around and the rollers look good on it. Am I able to use them??
KnappAttack
- Feb 19, 2004
- Welch MN
Size of the roller may be different but it will get you going, I'd use them for the last ride if the others are toast.
Rukus
- Dec 9, 2018
2012 Phazer RTX
2000 Venture XL
2013 Nytro XTX
Ya I took one out and the bushing is broken
Rukus
- Dec 9, 2018
2012 Phazer RTX
2000 Venture XL
2013 Nytro XTX
Hey Knapp, a buddy of mine has a new take off primary clutch from a 2025 sidewinder. Would it work on my 2017?
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Yes, it will work.Hey Knapp, a buddy of mine has a new take off primary clutch from a 2025 sidewinder. Would it work on my 2017?
Rukus
- Dec 9, 2018
2012 Phazer RTX
2000 Venture XL
2013 Nytro XTX
Beauty thank youYes, it will work.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
You may have to change weights and spring if you have any clutch work.Hey Knapp, a buddy of mine has a new take off primary clutch from a 2025 sidewinder. Would it work on my 2017?
Rukus
- Dec 9, 2018
2012 Phazer RTX
2000 Venture XL
2013 Nytro XTX
My current one is stock
KnappAttack
- Feb 19, 2004
- Welch MN
There is a difference in clutch weight placement from the 17 to the 25 just so you know. The 25 has less tip weight in it compared the 17. They use a different secondary setup between the two years as well if you run stock stuff.
Rukus
- Dec 9, 2018
2012 Phazer RTX
2000 Venture XL
2013 Nytro XTX
Ok so will it not work properly?There is a difference in clutch weight placement from the 17 to the 25 just so you know. The 25 has less tip weight in it compared tot he 17. The use a different secondary setup between the two years as well if you run stock stuff.
KnappAttack
- Feb 19, 2004
- Welch MN
If you are going to run the clutch right off the 25 you'll want the 25's secondary setup in it. Otherwise just put your 17's weights into the 25 primary as long as they are still good and not wore out or shot.Ok so will it not work properly?
Rukus
- Dec 9, 2018
2012 Phazer RTX
2000 Venture XL
2013 Nytro XTX
Thanks... Man nothing can just be straightforward can itIf you are going to run the clutch right off the 25 you'll want the 25's secondary setup in it. Otherwise just put your 17's weights into the 25 primary as long as they are still good and not wore out or shot.
KnappAttack
- Feb 19, 2004
- Welch MN
Well its not that hard. You could just rob the rollers out of it and send it too. Its the same clutch except the primary weight rivet change.
