SUPERTUNER
- Aug 16, 2003
- Waterbury, Connecticut
- www.easterncycleperf.com
rx1 fern said:freddie all my coils are arcing could this be my problem it keeps up to the apex till about 90 mph then the apex pulls on mebut i could feel it sputtering when i take off
ABSOLUTELY, POSITIVELY WITHOUT A QUESTION!!!
Freddie
- Mar 1, 2004
[quote="SUPERTUNER
Freddie[/quote]
Hey that 's my line Freddie...........
WE CAN SHARE IT
Freddie[/quote]
WE CAN SHARE IT
SUPERTUNER
- Aug 16, 2003
BOUNTYHUNTER said:[quote="SUPERTUNER
Freddie
WE CAN SHARE IT
I just borrowed the one time Bounty!
- Mar 1, 2004
NO PROBLEMO Freddie, I 4 GIVE U
Feel Free 2 use it Anytime
Skydog
You guys funny!!HAHA
goldbergrx1
this sounds similiar to mine after i had freddie install the ecp kit.....it doesnt do it all the time...i thought at first is was the belt......changed that, went to canada and did 500 miles with no low end sputter, then this weekend at old forge it started doing it again. i took out the 10 plugs and put back stock plugs and noticed it running smoother........freddie, should i also try that electric grease? if its not the problem then by putting the grease on will it cause a problem?rx1 fern said:freddie all my coils are arcing could this be my problem it keeps up to the apex till about 90 mph then the apex pulls on mebut i could feel it sputtering when i take off
SUPERTUNER
- Aug 16, 2003
goldbergrx1 said:this sounds similiar to mine after i had freddie install the ecp kit.....it doesnt do it all the time...i thought at first is was the belt......changed that, went to canada and did 500 miles with no low end sputter, then this weekend at old forge it started doing it again. i took out the 10 plugs and put back stock plugs and noticed it running smoother........freddie, should i also try that electric grease? if its not the problem then by putting the grease on will it cause a problem?rx1 fern said:freddie all my coils are arcing could this be my problem it keeps up to the apex till about 90 mph then the apex pulls on mebut i could feel it sputtering when i take off
Gary,
The dielectric grease is a band-aid of sorts. First check the sparklug caps/stick coils by removing them and removing the rubber top cap. Turn the lights off in the garage or do this outside at night. Visually look into the sparkplug well deep down inside the cylinder and see if you can see any arcing. If you want to swing by the shop, I will do this for you for free.
Freddie
