twyztid
- Feb 14, 2011
- Middleville, MI
- 2017 Sidewinder LTX SE - TD Power Trail, CAI, 3" Super Quiet
2012 RS Vector
2006 Apex GT
- Middleville, MI
Did anyone else here buy The Greaser for the ProCross sleds from Rockmeister at the snow any of the snow shows? I bought one in Novi but without the bearing. I am going to use my own NTN bearing. Hoping that it works well.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
I haven’t seen this product anyplace. What bearing does it go on in a procross? His fb and his website were only showing pro action and fx and rx chassis
twyztid
- Feb 14, 2011
- Middleville, MI
2012 RS Vector
2006 Apex GT
- Middleville, MI
I don't think they have it on the website yet but if you call or PM @Rockmeister, he'll likely be able to sell you one. I'll post some pics later.I haven’t seen this product anyplace. What bearing does it go on in a procross? His fb and his website were only showing pro action and fx and rx chassis
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Who has the driveshaft outlive the bearing?
Sticky foam between the tunnel and plate inside tunnel.
Waiting to see results of other people using it.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
It’s on the web site. There’s a drop down on the Greaser page for the different modelsI don't think they have it on the website yet but if you call or PM @Rockmeister, he'll likely be able to sell you one. I'll post some pics later.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Can we just hook up automatic greaser to that and give it a shot every 10 miles so the driveshaft won't wear out?
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
Would need more info to lay down cash for this product.
No information, instruction, or placement is given. Just
NEW! Bolt On Grease It Kit for all 2012+ ProCross machines (Cat & Yamaha) with new bearing is $120 + $10 Shipping (US)
Rockmeister is an advertiser here.
Hopefully they'll share additional information.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Checked it out at the snow show.
The metal plate, pcv fitting and bolts are for removing and installing the bearing in the caliper.
Can be done on the chassis.
The two black foam sticky back pieces are the greaser with the grease line.
And it comes with a new bearing.
Kenjeepman78
Just remember to remove the seal that faces the grease zerk and you should be ok.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 RS Vector
2006 Apex GT
- Middleville, MI
You don't remove the seal. They include a bearing that has 3 small holes on the inner lip of the seal for the grease to get in.Just remember to remove the seal that faces the grease zerk and you should be ok.
Kenjeepman78
Odd in the Apex forum I just asked and was told to pull the seal. Maybe if you are using you existing or replacement bearing it’s different than the one they include.You don't remove the seal. They include a bearing that has 3 small holes on the inner lip of the seal for the grease to get in.
Kenjeepman78
He said he was going to use his own bearing.You don't remove the seal. They include a bearing that has 3 small holes on the inner lip of the seal for the grease to get in.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 RS Vector
2006 Apex GT
- Middleville, MI
Completely different setup.Odd in the Apex forum I just asked and was told to pull the seal. Maybe if you are using you existing or replacement bearing it’s different than the one they include.
Hoosiersnow
That's a cool idea. I talked to Rock several times when I bought HID lights from him.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Any pics of this and how’s it work/install?
- 54K
