- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Just started on the 2007 Vector Mtn SE project. Have a pile of parts here to put on it and a few more parts yet still to come!
Pile of parts consists of:
-MPI Supercharger
-Lightweight hood
-Timber Sled Barkbuster Front End
-Lightweight seat
-Slydog Powderhound skis
-Fox Float front shocks
-Excell Motorsports high flow header
-Excell Motorsports Mountain Lite exhaust
-Timber Sled drop brackets
More pictures to come as the progress continues!!
Lexan Hood:
High Flow Header:
Supercharger:
-MPI Supercharger
-Lightweight hood
-Lightweight seat
Lexan Hood:
High Flow Header:
Supercharger:
AaronBND
Sweeeeet! Looks like you're having fun this weekend. Keep us updated!
Aaron
Aaron
sledskiing
- Oct 18, 2006
- Lakewood, CO
- www.sledmods.com
WOW
Is that a mountian fit hood?
- Apr 17, 2003
- Menno, SD
- Menno, SD
sledskiing, I'm not actually sure if it's a mountain fit hood or a snostuff hood. I picked it up from Pro116 off of here. Send a PM to him and he may be able to tell you which one it is!
- Apr 17, 2003
- Menno, SD
- Menno, SD
Few more pictures...
The tear down begins!!
Removed gas tank for high flow header install.
Removing parts for the supercharger install.
Skid removed (installing different track).
Track removed.
Stock header installed.
Muffler protector plate.
Stock header vs High Flow Header.
High flow header installed.
Track removed.
whitee
let the games begin
sledskiing
- Oct 18, 2006
- Lakewood, CO
- www.sledmods.com
I want that sled but can't afford it
The best I can to it to subscribe to this thread and live through you
- Apr 17, 2003
- Menno, SD
- Menno, SD
Just started the install on the supercharger components.
PTO drive install.
PTO drive install.
I bought the hood used but I think it's a sno stuff hood.
Look's great so far!
- Apr 17, 2003
- Menno, SD
- Menno, SD
Rest of today's progress. Time to go home for tonight and start on it tomorrow morning! I'm in the process of drilling the pilot hole for the supercharger stub shaft to go through the Delta Box when I realized I didn't have the 3/4" hole saw that I needed.
View from the front.
Fuel System Electronics.
Fuel Return block.
Another view from the front.
Fuel system installed.
Supercharger drive bracket.
Fuel Return block.
Mountaintech
Let us know what you think of the Barkbuster front end (especially the spindles) when you get it installed. Saw it at the Puyallup show and was quite impressed.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Some of today's progress.
Pilot hole drilled.
Supercharger installed!
Pilot hole drilled.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Today's progress. More work to be done tomorrow.
Just a picture of the hole required to be drilled through the Delta Box.
Picture of the special tool you need to tighten the supercharger shaft nut to torque it to 40 ft lbs.
Supercharger top bracket (I had to loosen the top oil line and rotate the line slightly so the bracket fit correctly.
Front View.
CDI position.
Modification of the battery bracket. It didn't quite fit how I liked so I modified it slightly for a better fit.
Picture of the front nose cone area.
Battery tray installed.
Front View.
CDI position.
Kachess
What a great project! I'm jealous. What a clean sled! What is the stuff that get's installed front of the bulkhead? Looks like the fuel pump is up top. I saw a brand new mountian vector the other day with the crappy old tunnel design. What's the difference between yours and it? Did the vector get the new ergos? (rider forward) That is the only thing that sled will be missing that seems to make a big difference. While you got it stripped is the time to do it.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Today's progress.
Removing the stock oil can from the air box.
New MPI oil can.
Oil can installed.
Battery, carbs, and air filter installed.
Intercooler installed.
Hood installed.
Airflow to the supercharger oil cooler.
What's next? Reinstall the stock exhaust for the moment as it will be the end of December before the Excell Mountain Lite is ready as well as the Barkbuster front end.
New MPI oil can.
Oil can installed.
Hood installed.
