zipclean
There seems to be a difference in which sec. spring was tested and which one was sent in the kits.I'm sure when T talked to John he said the springs with the tangs even with each other had to be set at 9/2 instead of 6/2.Anyone have his #.As I just took mine apart and the tangs are about 1" apart from each other and in the #9 hole there is basicly no tension.Somethings not correct????
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
507-288-5185
BADSLED
- May 13, 2004
- Syracuse, NY
2011 Apex SE
If your tangs are 1" +/- apart, setting 2 & 6 is correct. If your secondary spring tangs are in line with each other when lookin at the spring than you refer to the 2 & 9 setting.
Again, both these springs are the same except for the tangs. It's not a big deal, just identify your spring and use the approprate settings. Hope this helps.
zipclean
THanks guys ,just realized I got the stock and kit sec. springs mixed up.All O.K. now.Great site!!
cameljockey
please let us know how the kit works. pm me if you will. thanks.
Reaper
- Nov 10, 2005
- Starbuck, Manitoba
- 2014 SR Viper XTX. COTC, Hygear 141 pro link.
1" apart is wrong spring, wrap to 9-2. The 180 degree apart spring is 6-2.
