TurboMatt
Just finished up putting a new track under my sled. I noticed when bolting up the rear arm of the skid that the stock drop down brackets have multiple mounting holes. When I unbolted it it was mounted in the topmost hole. What would using the lower hole do? Would it help keep me on top of the snow better? i.e. keep my running boards from bottoming out on the snow.
yamahahaapex
I was wondering the same thing
niko
Got a pic? not sure which part your talking about.
niko.
niko.
yamahahaapex
I think he is talking about where the back two bolts mount into the tunnel to hold the suspension in. Or where the top 4-5"idler wheels are. So it's where two of the four bolts are located to remove the suspension. So where this bracket is there are 2 extra holes to bolts the suspension in. One a bit lower and forward and the other back and down a couple inches. I'm thinking it would just change the rear end and make it higher but I dunno. Would like to see some reports on this.
GotJuice
Not for me
I tried this before switching to Timbersled brackets and was NOT impressed, made the front plow bad and had huge ski pressure...if you were boosted I might see doing this to keep the nose down on climbs but not other wise. I'd actually like to raise mine to a higher bolt hole making it set up in the tunnel more to improve approach angle but there are pros and cons to both ways....always a compromise.
TurboMatt
yamahahaapex said:I think he is talking about where the back two bolts mount into the tunnel to hold the suspension in. Or where the top 4-5"idler wheels are. So it's where two of the four bolts are located to remove the suspension. So where this bracket is there are 2 extra holes to bolts the suspension in. One a bit lower and forward and the other back and down a couple inches. I'm thinking it would just change the rear end and make it higher but I dunno. Would like to see some reports on this.
Yeah, that's what I'm talking about.
2XM3
Re: Not for me
I agree 100%.....
GotJuice said:I tried this before switching to Timbersled brackets and was NOT impressed, made the front plow bad and had huge ski pressure...if you were boosted I might see doing this to keep the nose down on climbs but not other wise. I'd actually like to raise mine to a higher bolt hole making it set up in the tunnel more to improve approach angle but there are pros and cons to both ways....always a compromise.
I agree 100%.....
rx1tonofun
The lower hole directly below the upper is for better deep snow capability but not great for hardpack or marginal snow conditions. The other hole in the bracket was used to hold down the machine in the crate on earlier models and yamaha just kept it in production.
TomKat
- Dec 2, 2006
- Idaho
- 2006 SCAPEX
- Pocatello, ID
And here I thought that it was Yamaha's way of making it lightweight....lol! RX1 has it right (for deep snow conditions) although I have heard of the boost guys using it for the anti-wheelie factor.
- 8K
