mp5
- Feb 14, 2011
- New Brunswick, Canada
- 09 Nytro XTX
Yep...change battery for starters. Last thing you want is a dead batt on a 4 stroke Nytro on a cold morning (especially when not a home). Buy a new starter selenoid aswell...or clean that used one you have...and smear some dielectric grease on it.
I always carry a new back up starter selenoid w me...just in case. And while ur at it...switch out your relays w the red solid state ones. Once you have done all this...you should be good for quite some time. Oh...and always check to see if your batt connections are tight...loose ones can often times be the simple culprit
mpbrix92
- Nov 30, 2015
- Sheboygan , Wisconsin
- 2009 Yamaha Nytro RTX, pretty much bone stock
Do the red relays work with the 09 nytros without an adaptor or how does that work? Also are the relays that you’d be replacing next to the air box four in a row I believe?
mp5
- Feb 14, 2011
- 09 Nytro XTX
Those are the ones yes. I replaced all 4 on my 09 Nytro...no adapter needed.
Yamaha Vector LTX GT 2009
- Aug 3, 2016
- Rockwood, Maine
- 2009 Apex MTX
2009 Vector LTX GT
I had a bad starter relay on my vector and when cold outside I would go and try to start it and it would not start. So I would take a hair dryer and heat the relay up and it would start up. So then I got a used relay and that one did the same thing. So I got a brand new starter relay and it has been good ever since. When you try to start your sled in the cold and if it does not start then try to heat up the relay with a hair dryer and then see if it starts and if it does start then it is probably your relay.
mp5
- Feb 14, 2011
- 09 Nytro XTX
I have actually witnessed guys peeing on their Yamaha relay on crazy cold mornings (-33 C) to thaw them out....lmao....and it worked...
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
On my Attak the relay connectors didn’t look that bad. Where I had a problem was with heavy oxidation on the pins of the plug that connected into the top of the relay itself. I got the pins out and really cleaned them up AND replaced the relay starter so I knew I was working with good parts.
No I have not tried that is it easy to do
Yea it’s easy. Put the relay back in and take a screw driver or wire to make a connection between the 2 screws. If it starts up it’s not your battery.
Vector LTX GT 08
- Aug 3, 2016
- Rockwood, Maine
- 2008 Yamaha Vector LTX GT.
- www. Moosehead Lawn Care.com
- YAHOO
- colemanbodemer@yahoo.com
MP5, that is pretty funny, haha!!!I have actually witnessed guys peeing on their Yamaha relay on crazy cold mornings (-33 C) to thaw them out....lmao....and it worked...
mpbrix92
- Nov 30, 2015
Guys I appreciate all the feedback if possible can anyone post a picture of the starter relay. I took out what I believe is the starter solenoid but I’m not sure if that’s the same as the relay or where the relay is I appreciate the help
mp5
- Feb 14, 2011
- 09 Nytro XTX
Here you go. FAQ section on top of the page...good reads for you
https://ty4stroke.com/threads/fault-codes-relay-fuse-location-wire-diagram-diagnostics.83992/
mpbrix92
- Nov 30, 2015
Thanks MP5 will the red ssr replace my current starting solenoid
Yea what you took out isn’t the mechanical relay that gets replaced with the red ssr. The red ssr goes under the hood to the left of the steering rod base. There are 4 black mechanical relays mounted in a rubber housing that’s a real pain to get to unless you take some stuff apart.
What you took off is the starter relay. It’s the fuel pump relay that’s problematic under the hood.
The green thing next the the starter relay you removed is a fuse.
mp5
- Feb 14, 2011
- 09 Nytro XTX
Exactly. I would replace the battery...the starter relay (under hood by battery), and at least the fuel relay at the front left beside steering arm (3rd one back). I replaced all of them while I had the relay panel apart.
mpbrix92
- Nov 30, 2015
Alright thank you guys I apologize Im not the most mechanically encluned but I’m trying to learn to do it myself Incase I have problems while riding
mpbrix92
- Nov 30, 2015
Yeah I’ve taken most os the panels of but am having issues getting my hand in by the relays
- 8K
