SRTGTOCJ7
- Feb 25, 2020
- Jersey/ ADK
- 2023Sidwinder L-TX LE EPS.
2019 Sidewinder L-TX DX
2000 SXR 700
1997 VMax XCT 600
Thanks,
John
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
sab2022
One newbie to another go through the post below , every page, I forget what page the muffler bolts are on but, yes what actionjack said basically remove the torx from the socket (buy a socket from Lowes/HD) then put a wrench on the just the t0rx to get the other two bolts out. I ordered a little longer mm SS Hex Bolt then rockerDan recommended
https://ty4stroke.com/threads/my-rtx-le-50th-build-thread-rockerdan.149801/
sab2022
BTW- I'm doing the panel rivet nut mod (both sides) and don't use the harbor freight rivet nut tool breaks with SS rivet nuts.
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
I see that this is your first post here SRTGTOCJ7. Welcome to the site! There's a lot of great information here to keep your sled in top shape with lots of resources available.
Here's a link that I found for you that contains everything that you'll need to help you to remove those pesky Torx bolts on your exhaust:
https://ty4stroke.com/threads/removing-exhaust.145783/
I found this link in the SideWinder Trail Talk forum under the "SideWinder Frequently Asked Questions" thread that's near the top of the first page. I'd recommend taking some time to learn all of the valuable resources on TY.
You might also consider joining as a VIP member to take advantage of the rest of the benefits that TY has to offer. I don't believe that you'll find another site that has as much to offer to keep you on the snow and in the know.
https://totallyamaha.com/Totallyamaha/Store/vip.htm
I see that you've already had a couple other TY members chime in with some info so you can see just how helpful everyone is here
Here's to a great winter riding season.
Cheers!
Cheers!
actionjack
- Apr 9, 2005
SRTGTOCJ7
- Feb 25, 2020
- Jersey/ ADK
2000 SXR 700
1997 VMax XCT 600
Thanks Actionjack. That worked and yes 8mm. Only thing else I needed to do was shorten the T50 it was still too long.
got to love engineers!
no1b4me
Just do yourself a favour to make things easier for yourself next time and exchange the T50 for 6 point header exhaust bolts.....M8x1.25x20mm
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
Make sure to reinstall with Nickel anti seize and check torque value in manual. I torque a bit under described with no issues.
sab2022
I guess I'll use this thread to ask my newbie question. How do I [you] remove the muffler? AND is there any other hardware, other then the 6 discussed above, that should be nickle anti-seized because of heat?
Recognizing the six bolts (#5) need to be removed. There are grommets (#6 (2), #9). Are there muffler pins that go into the grommets? Meaning, what holds the muffler in the grommet? It looks like I lift the muffler up to remove it. What's the function of the spring (#21) behind the muffler - I don't like hidden springs. Can I reuse the gasket #8 on a new sled with 0 hours, or is it a crush (one use) type gasket ? I assume the muffler shielding comes with the removed muffler.
no1b4me
One spring to be disconnected and lift the muffler assembly out, once all 6 of the T50 bolts have been removed.
SAB1
- Mar 1, 2011
- Tuftonboro NH
2010 Vector GT
2006 Apex
Very simple. Take of the heat shield the bolts and spring. Heating the the bolt housing helps a lot. Nickel anti seize will take the heat and make bolt removal easier
sab2022
Thanks all I guess that spring is P/N: 21 and I'll gamble with the gasket. I'd like to touch that gearcase adjustment screw
swampcat
Get use to it, because thats about the ONLY way to get to that bolt.Thanks all I guess that spring is P/N: 21 and I'll gamble with the gasket. I'd like to touch that gearcase adjustment screw
VyperNation
- Feb 4, 2018
- MI
- 21 Winder XTX LE 146
18 Winder XTX SE 137
--past sleds--
18 Viper LTX DX
(2) 06 Apex RTXs
99 Vmax 500
Get use to it, because thats about the ONLY to get to that bolt.
Unless you do the rivnut mod. A project that will pay for itself for as long as you own the sled!!!!!
- 14K
