Removing float from secondary
Be careful,not to much deflection! if you run the belt to tight it will rub inside on the primary shaft before it "squilll"
Just slightly above secondary ;)!
For sure, I'm about 1/8th below the top of secondary now.
This is how mine is set up.
First I set my offset with the hurricane offset tool.
Second I cut the aluminum plug to be flush with the clutch hub. This is my clutch bolt......The washer next to the aluminum plug holds my clutch from floating. The two small washers are used to set my belt deflection. I don't need to take my clutch apart to adjust deflection.
Make sure the washer used to remove float will fit inside the helix bushing.
I'm running darn near same setup as OP but I like the BOP adjuster, so when I blow a belt I can use the adjuster as a belt change tool, and also it adjusts deflection perfectly. No need for shim washers, just the 4 washers Travis sent with the long bolt.
All my info here:
https://ty4stroke.com/threads/my-rtx-le-50th-build-thread-rockerdan.149801/page-34#post-1449153
Large fender style washer to stop float is 35-36mm OD X m10 ID.(approx 2-3mm thickness)
I also use an Apex shim overtop of the float plug, to dial in the float and not side load the bearing.
Dan
img_3839-jpg.144425
img_3840-jpg.144424
img_3845-jpg.144419
Dan, why haven't you put a washer that matches the diameter of the BOP belt adjuster or one slightly smaller? That would bug the crap out of me. Can you actually get enough leverage with that adjuster to change a belt with a stout spring in there?
i'm running darn near same setup as OP but I like the BOP adjuster, so when I blow a belt I can use the adjuster as a belt change tool, and also it adjusts deflection perfectly. No need for shim washers, just the 4 washers Travis sent with the long bolt.
Dan
img_3686-jpg.144067
img_3687-jpg.144066
img_3688-jpg.144065
img_3690-jpg.144068
img_3689-jpg.144069
I’m running same setup Dano! Works mint being able to lock down the secondary and still have the adjustability with Travis’ tool. Love it!
500 miles with nothing but smiles so far running 290hp
Not sure what you mean....but this setup is perfect.
Easily change belts with the allen key, do it all the time.
Dan
:dieFirst you all want float now you all don’t want float, what’s going ON!!!!!
I am going to leave my float @3mm. Set it perfect with the Hurricane tool and let it float outward @2-3mm.
The stock float is set up just like the Apex with about 1mm of float.
When i started using belt remover/adjuster tools, they came with a lot of float. Mine was 4 to 6mm or maybe more. I can't remember.
3 years ago, like Danno says, it was all the RAVE.
After blowing 7 belts i decided to look into a few things. I went back to my AAEN clutch book.
In theory the secondary should always push in, but sometimes it "floats" back as in braking. I just believe there are times when that float is in the wrong place at the wrong time, then 200 Horse Power says BAMMM!
Once Mr Knapp mentioned it, i removed my float to 1mm just like my 5000 mile per belt Apex.
Like sooo many clutch gurus here have said, a couple mm's shouldn't be blowing belts, but if i was off with my offset and i had 4mm of float then i could have been 6 to 8mm off at any time.
In the Porn world, an extra 8mm doesn't make you a star, but in the clutch world....................that's a lot!
I was always of the opinion that float solely existed so that when the bolt that holds the clutch on was tightened, the bearing wasn't pushed on the jackshaft. When Doo came out with the stepped jackshaft against the bearing, which meant no more bushings, spacers and little washers on the bolt, I thought that's brilliant(and about time).a lot less f'in around.
I left about .2mm only, using an Apex shim overtop.
Full write-up here:
Ill paste it in here for those that dont click above.
Removing the float while using the BOP belt adjuster
I was able to set up my BOP adjuster very nicely. Travis should like this! ;) So anyone with the BOP adjuster, this is an easy setup with a few easy mods and a 35mm OD washer.
This setup will allow for belt deflection adjusting, and also removal/installing belts as we all love, and will remove the float fully or just the amount you want.
Lowering the offset as per the Hurricane alignment bar, Secondary hub backside gets machined down, and so the secondary slides inward approx 3 to 4mm. To reduce the massive amount of float that is produced afterwards, material needs to be cut off the stock aluminum float plug. So first get your secondary exactly where the Hurricane bar wants it.
Once secondary is sitting perfect with Hurricane alignment bar, insert the stock alum float plug. The alum float plug will get cut down close to flush with outer hub..... When I cut mine, I left it a tad longer then flush, and used an old Apex shim OVERTOP of the Alum float plug to remove the float down to approx .2mm(Basically nothing). These shims are much larger and fit over the alum plug like the apex used to have(pics below).....I like to allow for this small spacing so there is no side loading when bolted tight.
NOTE: Initially the amt left hanging out of my HUB was 7mm!(check yours as not all will be exact same). That large amount of float, is increased if using the belt adjuster, as hub may float inside the adjuster even further outward once into the shift. This is where the 35mm washer comes into play.
Next in line to the newly cut down float plug, you need a larger fender style washer, be sure its thick enough too. I found fastenal has 10mm X 35mm OD X 2.5mm thick.
Next we use the 4 small washers that Travis includes in his adjuster. This helps as the main bolt he gives you is very long, and also helps with adjuster to remove belts.
Next is the adjuster itself.
Next I use a large washer outside, i chose one that is a tad larger then BOP threaded adjuster diam, so if the adjuster ever came loose, it cannot spin off.
Now the adjuster works as a deflection tool and also a belt change tool too. Possibly Travis will include a 35mm large washer for guys who want no float ;)
Remember, the '12 cats had this float setup with the helix, and they were belt killers, and now the new Cat 998s are locked down like the doos, and sure enough their belt life seems reasonable. Time will tell.
Dan
Notice the thin Apex shim on left, overtop of Alum float plug.
img_3838-jpg.144426
Float plug,Apex shim, 35mm fender washer, 4 washers came with BOP adjuster, BOP adjuster, large washer.
img_3839-jpg.144425
img_3840-jpg.144424
img_3841-jpg.144423
img_3842-jpg.144422
img_3843-jpg.144421
Apex shim sitting overtop of stock float plug,dials in perfect amt of float(.2mm now,so basically nothing)
img_3844-jpg.144420
All tightened up and deflection set where I want with Adjuster, also used for removing belts easily.
img_3845-jpg.144419
img_3846-jpg.144418
Fastenal washer Part#: 11512281
fullsizeoutput_9e8-jpeg.143129
Full write-up here:
Dan
img_3838-jpg.144426
img_3839-jpg.144425
img_3840-jpg.144424
img_3841-jpg.144423
img_3842-jpg.144422
img_3843-jpg.144421
img_3844-jpg.144420
img_3845-jpg.144419
img_3846-jpg.144418
Nice write up Dan!
I felt this is so important in belt life that I made this thread instead of having it buried in other topics.
Jesus Dan!
Can you do a thread on how to include all this info on these threads?
I mean i'm not as bad as SNOWBEAST, but i feel sooo inadequate!
Jesus Dan!
LOL.....Its hard to keep up with this sled i swear. We all need to be engineers here at TY just to get a days ride in and make it home..haha.
