KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
My buddy could eat them up in one day on his Winder primary. For whatever reason, he and I both switched to a Apex & RX-1 primary clutch this season and both of our rollers are lasting and the the performance is better too. Why the rollers last longer, I can only assume because there is less pressure on them being closer to the shaft centerline. One other thing I noticed is my Winder primary seems to bind on the shaft or the towers, maybe both, but the winder primary is sticky and not smooth like the old Yamaha clutch.
rxwhopper
how is the viper primary different then the apexMy buddy could eat them up in one day on his Winder primary. For whatever reason, he and I both switched to a Apex & RX-1 primary clutch this season and both of our rollers are lasting and the the performance is better too. Why the rollers last longer, I can only assume because there is less pressure on them being closer to the shaft centerline. One other thing I noticed is my Winder primary seems to bind on the shaft or the towers, maybe both, but the winder primary is sticky and not smooth like the old Yamaha clutch.
KnappAttack
- Feb 19, 2004
- Welch MN
Same clutch. Maybe different clutch rollers is all.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Apex also has the set screws to hold the roller pins stationary, but that’s the only difference in the two spider assembly’s.
No, they are much different as the Winder clutch spider doesn't thread to the stationary sheave.Apex also has the set screws to hold the roller pins stationary, but that’s the only difference in the two spider assembly’s.
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
I was talking about Apex spider vs Viper spider, not Winder.No, they are much different as the Winder clutch spider doesn't thread to the stationary sheave.
KnappAttack
- Feb 19, 2004
- Welch MN
interesting, I didn’t realize the Viper clutch didn’t have set screws on the roller shaft.
The rx-1 and apex clutch has set screws.
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
Pretty sure the ‘11 + Apex sleds were without the spider set screws as well Mike. Eliminating them never really made much sense to me. Anything you can do to stop the steal pins from turning and wearing the aluminum castings is a good thing my eyes. I’d rather replace bushings than clutch parts.interesting, I didn’t realize the Viper clutch didn’t have set screws on the roller shaft.
my 11 apex had the set screws for the pins in the clutch when i replaced it because of cracks in the clutch faces.
I remember seeing a Vmax4 of Iantomassi racing with the hood open. They used the set screws only to hold the weight pins and roller pins. No bolts.
