ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Yeah i see a ton of those over there.....great sleds too!I was a hair away from getting a 7000 Limited leftover from there. Wife says I need a new truck first. Still bugging me since my truck never made me walk!
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
That Tundra will never strand you.....I was a hair away from getting a 7000 Limited leftover from there. Wife says I need a new truck first. Still bugging me since my truck never made me walk!
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
RtxViper
- Feb 24, 2007
- Deerfield, Wisconsin
- 2019 SRX LE
How do you tell if these are bad? Are they oblong and the gear is sloppy on the shaft? I have mine apart right now and if i hold the gear on the shaft i can get a little play from it side to side, i would assume i should have none. The bushing itself looks good but like i say there is a small amount of movement. When this does go bad is it just a bad vibration that is felt or something worse that happens?
If grey coating is gone on over half of it the wear is measurable and I would replace. Not saying it may last longer without damaging anything but I would not chance it.How do you tell if these are bad? Are they oblong and the gear is sloppy on the shaft? I have mine apart right now and if i hold the gear on the shaft i can get a little play from it side to side, i would assume i should have none. The bushing itself looks good but like i say there is a small amount of movement. When this does go bad is it just a bad vibration that is felt or something worse that happens?
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Not available in canada or US from SKF "america"Anyone try this bushing?
Skf PCZ 1616 M
I seen a guy posted this other the day on a different site
I can order from europe but minimum order is 25..... ~~4$canadian each +duty and shipping. I am on hold.....
JPS
- Aug 23, 2014
- Clarks Summit, Pa
- 2018 sidewinder XTX, 2017 Viper XTX, 07 apex attack, 95 Vmax4
I am with you there, riding big moguls and a tight goat path is what i did when i was 18 and did not know any better, i still make some 18 year old decisions like blow a lot of cabbage on a turbo sled but smooth fast trails just feel so good!!We're like that Hot Crazy Ex-girlfriend to Dan. He just can't stay away.
Great in the sack, but.....................................................................................just CRAZY!
Dan needs 2 sleds. I used to ride VT where i'd be better off on an 850.
That's why i ride Maine!
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Stain whats the first one?I bought these bushings to try.![]()
STAIN
- Feb 29, 2004
- Vermont
- Vermont
left to right BB-16 Sintered Iron/Copper Sleeve, Oil & PTFE Impregnated Sleeve, Steel Backed PTFE Lined Sleeve Bushing, Oil Impregnated Bronze Sleeve
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I pressed the BB-16 Sintered Iron/Copper Sleeve in first to my 21 tooth gear. It was to tight on the shaft.
I then pressed the Steel Backed PTFE Lined Sleeve Bushing in. It fit the shaft perfectly with no slop or side to side movement. It was also super smooth on the shaft.
Do we think that will last?
I am going to try the bronze sleeves also and test for fit.
I really have no clue. I suspect anything with the PTFE coating will not last since that is what wears off of the stockers first. At that point it depends how thick the coating was on there as to how much play gear has when worn off.I pressed the BB-16 Sintered Iron/Copper Sleeve in first to my 21 tooth gear. It was to tight on the shaft.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
What kind of lube are you guys running in these chaincases?
Just doing some pre season maintenance now, over 11000 kms, stock top gear with no oil holes and the bushing is still mint, No gold worn off the bushing, tight on the shaft still. I run my chain tighter than spec, and use mercruiser outdrive lube in my chaincase.
Turboflash
- Mar 18, 2019
- Southern MN
I believe there's been multiple threads here on this subject. Maybe do a search (box top right of the page)? There's a wide variety of lubes being used.
Jafo1970
- Dec 2, 2016
- oshkosh, wi
- 17 sidewinder, doo 850
I use synthetic tranny fluid. Switched to this in 2013 after the first bushing failure left me hanging. Been using this for over 10,000 miles now in 3 different sleds with this chaincase. No issues.
