![](/styles/vip.gif)
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
Can anyone tell me the position of the ex-up cables on the servo pulley? they both broke and wound up inside if the servo housing and i cant tell how they were positioned.
![](/styles/TYLifeMember.gif)
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
Here's a pic of mine when one broke a few years ago. Black cable routes over the top, silver goes around the bottom.Can anyone tell me the position of the ex-up cables on the servo pulley? they both broke and wound up inside if the servo housing and i cant tell how they were positioned.
Is this what you need?
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
Thanks Redbeard, that is nice too. But I need the other end, in the servo box
Redbeard
- Oct 14, 2011
- IN
Give me a few minutes and I'll go out to the shop and snap a pic of that end.Thanks Redbeard, that is nice too. But I need the other end, in the servo box
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
I appreciate that. Im not sure what cable goes into each hole, and how they are wrapped around the pulley
Redbeard
- Oct 14, 2011
- IN
The black cable routes to the top of the EXUP valve pulley, and to the bottom side of the servo motor pulley.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
Haha, inside of the servo box . Dont take yours apart, i will figure it out when i get my new cables. Thanks for going out a taking a pic for me. I like the bolts that hold your cover on ALOT better than my Allen head stockers. Im hitting the hardware store after work tomorrow for sure.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
I just reread, bottom hole.....Thank you VERY much!!
Cummins6.7pwr
- Dec 5, 2008
- Monticello, Iowa
- 2011 Yamaha Apex XTX
Both of my cables and valve are positioned in the trash can... eventually, yours will be too! ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
Probably. I will fix it once. If/when it breaks again. I'll junk it
Firedawg1998
- Oct 17, 2018
- Sudbury, Ontario
- 2019 srx
Hurricane PM bundle
2012 apex xtx
2012 vector gt
Ya, I hear that.... to the above post... on my 4th winter with my 12. Now has 16000 k. First and only apex I ever drove is mine. I tried to check my ex up the first winter but couldn't get one bolt out of the cover so I just left it alone as the sled moves like crazy. This year I decided I had to get in there to inspect it. Sure enough one cable had a clean break in it and the top cable was snapped also but had unwound itself over an inch backwards. That makes me think it was broke for a loooooong time and the vibration slowly caused the separation. I found the valve sitting in the 8 o'clock position. So to try things out this year I just wired it at 3 o'clock and have been out cutting the trees on our local trails as they are un groomable at this point. I have to say.. maybe the valve does indeed increase mid range and ,maybe I forget how much power these sleds have. But mine is pulling extremely hard down the straights I encountered on old unserviced logging roads. The drone at 4500 seems slightly less annoying as well but still there. So I may not fix it at all. Easily 100 dollars for the cable and the top of my tunnel is all heat stained and discolored above the valve... I think it was partially closed for the few past seasons causing exhaust to go around the top of it. Sled never pulled over 106mph either... so now I just need to find a safe place to test that.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
Keep us posted on your findingsYa, I hear that.... to the above post... on my 4th winter with my 12. Now has 16000 k. First and only apex I ever drove is mine. I tried to check my ex up the first winter but couldn't get one bolt out of the cover so I just left it alone as the sled moves like crazy. This year I decided I had to get in there to inspect it. Sure enough one cable had a clean break in it and the top cable was snapped also but had unwound itself over an inch backwards. That makes me think it was broke for a loooooong time and the vibration slowly caused the separation. I found the valve sitting in the 8 o'clock position. So to try things out this year I just wired it at 3 o'clock and have been out cutting the trees on our local trails as they are un groomable at this point. I have to say.. maybe the valve does indeed increase mid range and ,maybe I forget how much power these sleds have. But mine is pulling extremely hard down the straights I encountered on old unserviced logging roads. The drone at 4500 seems slightly less annoying as well but still there. So I may not fix it at all. Easily 100 dollars for the cable and the top of my tunnel is all heat stained and discolored above the valve... I think it was partially closed for the few past seasons causing exhaust to go around the top of it. Sled never pulled over 106mph either... so now I just need to find a safe place to test that.
