rivet nuts
I think the gold color cad plated rivet nuts are best suited for this. S.S. reacts badly with steel and causes the steel to rust quickly as does aluminum. Dissimilar metals cause a galvanic reaction. Especially if you through salt in the mix.
I have a matco gun but I use it all the time
Great thread. Didn't know it existed. I've been emailing rockerdan for help. Just curious what tool you guys have used for the rivnuts. A lot of the write ups on the net don't speak highly of many of the tools. Also seen a few videos on home made tool you can make with bolt nut couple washers and a coupling nut. No doubt I'm doing this but will be using stainless steel rivnuts for sure. Just gotta find a nice screw with big head
Point us to a link got them if u can. Did u get them in different lengths to accommodate the thicker material in areas like Dan mentioned?
Link for them. Sorry fat fingers ...
Polaris Razor push pins...
I found them on Amazon with a gun and assortment of metric nuts! I'll see if I can find the link, I was last Nov .
**sj**.............just wondering if you've used those plastic push pins on the lower sided panels and how well they did the job?
Hi Steve,can you share some more details on size,and how they hold up,and how you installed them correctly? Thanks
Ok finally got it done
I’m pleased with overall outcome
M6 SS and aluminium
WINGWONG- Is there room to do the rivet nuts with that tool when the handles are expanded all the way out for each one?
Hi that’s a great question—-> It was a bit tricky around the shock. It worked though, I had to remove the nut on upper shock post. Other than that it worked great
Highly recommend doing it
Alternative to rivnuts. Not sure how this will stand up, but after drilling out the rivets I used a 1/4”-28 tap on the holes except for the 2 by the footwell.
Steve barn of parts sells them to,in packs of 10 but I cant seem to find them on his site now that I need them,i wonder if the poo poo rivets are same size?
I will be doing this mod shortly and report back
Hi steve,have you done the push pins yet? And did you run barn of parts or Polaris?
